b20 idle
Old Feb 9, 2008 | 10:01 AM
maxx5905's Avatar
Default b20 idle
Ok heres the thing. I own a b20b and trying to get the idle steady. I have checked for vac. leaks(spraying carb cleaner) switched out IACV, adjusted valves. Any idea what it could be? The idle surges when i give it some go juice and hold it, it sounds as if it is missing. Ive also checked the timing but with it surging its hard to get it just right.
?????? Please Help!!
Old Feb 9, 2008 | 03:13 PM
jrcivicep3's Avatar
Default Re: b20 idle (maxx5905)
i heard of this same thing on antoher forum, ill see if i can find the thread
Old Feb 12, 2008 | 03:55 PM
maxx5905's Avatar
Default Re: b20 idle (jrcivicep3)
bump
Old Dec 19, 2010 | 01:22 PM
TegraB20's Avatar
clean iacv, if u did clean FITV
Old Dec 19, 2010 | 06:28 PM
tonythetuner®'s Avatar
Clean fitv its under ur throttle body. Take it off open it up and tighten the white plastic screw in side and clean with parts cleaner. Should fix ur problem. Search how to clean fitv
vtec5genhatch
Mar 17, 2013 08:25 AM
blacknightteg
Jun 16, 2009 09:57 PM
Highlifer
Aug 4, 2007 08:12 PM
Boostedb20EH2
25
Apr 26, 2007 07:14 PM
CivicEx95
Feb 7, 2003 03:42 PM
