HID's don't work on my ES(2001 Civic)!!!
Took the working PnP kit from my EG and treid to hook it up to my ES and they don't turn on.I checked the fuse and it's already running a 15a and in my EG the 10a fuse worked fine.I've already searched and did not come up with anything.
If the kit does not have a relay harness. Turn on your high beams.
If the kit does have a relay harness, put the ground on the negative post on the battery and the 12v wire on the positive post on the battery. After that, just double check to make sure the other connections are nice and tight.
91efbluehatch
Dec 29, 2010 02:50 PM
