how do u adjust the fuel pressure?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeenox »</TD></TR><TR><TD CLASS="quote">how do u do this? cause i just got my car and im working on it and it has high fuel pressure </TD></TR></TABLE>
A: It is not adjustable in stock form, as it is decided by you fuel pressure regulator, that is not adjustable.
B: What is your fuel pressure actually at, other than "High"?
well i had a d15b7 swap in and i can notice that engine is receving too much fuel .. cause the car throws alot of smoke and it smell like gas when i drive it and idles messed up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeenox »</TD></TR><TR><TD CLASS="quote">well i had a d15b7 swap in and i can notice that engine is receving too much fuel .. cause the car throws alot of smoke and it smell like gas when i drive it and idles messed up </TD></TR></TABLE>
you need to tell us more info!
We cant help you if you dont help us!
What was in the car before the 1.5 lame swap? and dont tell me another 1.5 was in there or your telling me you replaced the engine not swapped it.
You might have a many number of different problems.
i REPLACED the engine from the stock d15b1 to a 92 d15b7..cause the old motor the car had was blown and old. could it be the fuel pump throwing too much fuel?..and i have survived with 632 post cause i have bought cars that work fine and paid people to do the work for me but right now im just tryin to learn how to stuff and im 20 and tryin to learn for fun cause i have notin else to do
Once again: It is your fuel pressure regulator that decides your fuel pressure. Not your fuel pump. What is your fuel pressure at? Just because you are getting too much fuel (As you are assuming), does not meant that your fuel pressure is too high.
I actually have a prob with my fuel as well. I got a ls vtec with stock ls block with a b16 head. I have an adjustable fuel pressure regulator silver in color no idea of the brand. I had to buy the guage separate. Its the one that goes on top of the fuel filter. For some reason I can't get the pressure to go pass 30psi. I was told that's pretty low. My car doesn't smoke or over heat. It just feel like it needs more??? I have a stock p28 which I want to chip out after I get the car running better. I tried putting in a chipped computer and I felt no difference. I'm sure a Stock ls could beat me right now the way my motor is running. I took of the head got it checked and milled. Put on a new HG. I NEED HELP!!!
well wat can i do to stop my car from smokin ..besides changing my exhast system cause my old one is rusty and it has holes. can that be causing the smoking? and my car gets crappy gas milage
Do you have a check engine light on???
If you smell fuel out the exhaust your car is running rich.
What color is the smoke...black???
Its not your fuel pump.... Could be something simple like an oxygen sensor.
you need to relieve the pressure (bleed) like they did in the old days. Take your car into a comfortable spot and slowly cut a small hole in the fuel line. Make sure you have a bucket under the hole. Now you need to close your hood and the rest will heal it self. Make sure there is no infection......................................... .........
Oh wait, I thought this was a medical forum sorry guys.
REPLACE O2 SENSOR
REPLACE O2 SENSOR
well my dash doesnt work it needs to get rewired so yea i dont know if it has a check engine light on but if it is the a cracked block or a bad head gasket its prob a bad head gasket...but yea imma buy a new head gasket and exhast system and a o2 sensor
