lube/oil your sunroof??
ok so sud i lube/oil my sunroof? it goes kinda slow sometimes and makes weird noises sometimes also.. is there a way to lube it?? any help wud be thank ful...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 418whpturboD »</TD></TR><TR><TD CLASS="quote">ok so sud i lube/oil my sunroof? it goes kinda slow sometimes and makes weird noises sometimes also.. is there a way to lube it?? any help wud be thank ful...</TD></TR></TABLE>
not only will it be slow the seals will get hard and crack causing it to leak. I just take some vaseline to to the rubber seals
every couple of months to keep it soft.
If I had to recommend anything, I'd say do the following:
Clean it occasionally (several times a year) by wiping it down with a damp cloth. Don't remove the track lubrication (white lithium grease) though.
Use a silicone spray lubricant on the seal if it needs it. (I'd apply it with a cloth also.)
11
Aug 19, 2004 05:17 PM
