2 stupid questions...
Old Feb 8, 2008 | 09:43 AM
SolAssassin's Avatar
Default 2 stupid questions...
Next to the brake booster is a line coming out of the firewall, pointing up. When I got the car, there was a heater hose attached to it with a screw on the other end plugging it up. What is this line for and what is it supposed to connect to?
Also, there is a torx bit underneath the proportioning valve on the p/s fender wall that holds a bracket to it. Does anyone know what size this is?
Old Feb 8, 2008 | 11:46 AM
wiZCo's Avatar
Stouts 'n' Scotch
Pics?
Old Feb 8, 2008 | 11:52 AM
Default Re: (wiZCo)
i will take some tonight
Old Feb 10, 2008 | 08:31 AM
Default Re: (wiZCo)
the line sticking up between the booster and the clutch cable...
Old Feb 10, 2008 | 12:52 PM
90civSi's Avatar
Default Re: (SolAssassin)
im not 100% sure cuz i dont have a car infront of me but i think it is the fuel return line?
Old Feb 10, 2008 | 03:27 PM
Crx Jimmy's Avatar
Default Re: (90civSi)
yeah, its the fuel return line.
Old Feb 10, 2008 | 05:10 PM
Default Re: (Crx Jimmy)
return from what? the carb? do i block that off?
Old Feb 10, 2008 | 05:44 PM
Crx Jimmy's Avatar
If this is a US car then it never came with a carb here. its the fuel return line , it returns the unused fuel to the tank, What more is there to explain. after the FPR the fuel RETURNS to the tank
Old Feb 10, 2008 | 05:51 PM
sgallagher's Avatar
Default Re: 2 stupid questions... (SolAssassin)
You should reconnect that to the fuel pressure regulator on the fuel rail and make sure you have the vaccum line hooked up to the fpr. If you do not you will be allowing too much fuel to be used which is not always good. Also you will get poor fuel mileage if it is not connected.
Old Feb 10, 2008 | 07:30 PM
Default Re: 2 stupid questions... (sgallagher)
weird place for the fuel return imo...
i'm used to it being lower in the engine bay
thanks!
Old Feb 10, 2008 | 08:54 PM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolAssassin &raquo;</TD></TR><TR><TD CLASS="quote">weird place for the fuel return imo...
thanks!</TD></TR></TABLE>
It's actually a nice place my opinion. Easy and convenient.
Old Feb 11, 2008 | 01:44 AM
~sp33~'s Avatar
EFB055
Default Re: 2 stupid questions... (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
It's actually a nice place my opinion. Easy and convenient.</TD></TR></TABLE>
unlike EVERYTHING else on the car.
Old Feb 11, 2008 | 02:22 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 2 stupid questions... (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">
unlike EVERYTHING else on the car.</TD></TR></TABLE>
LOL, you've never worked on a VW before, have you?
B_Swapped93
Apr 4, 2019 10:02 PM
lejeaune
Feb 24, 2012 08:31 AM
double b from wv
Jul 8, 2009 08:03 PM
JLefevers
Jan 1, 2008 09:20 PM
IMSTOCK
Aug 23, 2004 08:46 PM
