Squeaky Steering Wheel *help*
Old Feb 8, 2008 | 07:15 AM
Shaguar47's Avatar
Default Squeaky Steering Wheel *help*
My 91 4dr lx has a very bad squeaky steering wheel. Everytime you turn it while driving or parked, it squeaks and it's loud. I took apart the whole steering wheel assembly and lubricated all the junk that rotates with the steering wheel such as the horn contact plate and some small plastic pieces. I can't figure out where it's coming from and it's the last thing I need to do to the car.
Old Feb 8, 2008 | 07:36 AM
D50boy's Avatar
Default Re: Squeaky Steering Wheel *help* (Shaguar47)
I was going to say it would be the horn contact :/ You might try spraying some WD40 into the shaft. How that would be done... not sure.
I'm no help
Old Feb 22, 2009 | 12:30 PM
Coltmorris's Avatar
I have the exact same problem. I took the wheel off, not only sprayed the contact plate with wd-40, but I also re-bent the plate itself to prevent any further squeeling. Eventually the squeel slowly came back as the contact plate bent back to its original squeeky position. So I dunno what to do, buy a new hub assy.? Any other thoughts?
Old Feb 22, 2009 | 02:04 PM
RB_EJ8's Avatar
I have the same problem on my hatchback
Old Feb 22, 2009 | 05:09 PM
KB91Hatch's Avatar
I had this problem but I replaced my front end compliance bushings and it went away. don't know if that will help. it sounded like the wheel itself but it ended up being from the front suspension.
Old Feb 23, 2009 | 04:56 AM
Coltmorris's Avatar
This, for me, is most definately the contact plate scraping/squeeling. Ill have to take the wheel off again and see what would have to be done to replace the horn plate...
Dezso3
Honda Civic (2006 - 2015)
Dec 11, 2015 08:57 AM
^^ gökan^^
Suspension & Brakes
Jan 31, 2010 11:53 AM
b00stME
Suspension & Brakes
Sep 8, 2006 02:05 PM
LBCek9
Dec 22, 2005 08:40 PM
95dc2
Jan 26, 2004 04:37 PM
