Windsheild wiper issue 1992 S Model
Old Feb 8, 2008 | 05:43 AM
IMPORTMyth01's Avatar
Default Windsheild wiper issue 1992 S Model
Just bought a 92 S model Prelude and the wipers will work on ALL settings when on but when you turn them off they do not return to the bottom, they stop whever they are. Also when driving the wipers will magically turn on and off whenever they want to. It is as if they have a mind of their own, I read about the relay under the CMS and the fuses are all good. Replace the actual switches on the steering wheel?
Thanks in advance
Old Feb 8, 2008 | 06:03 AM
Apex1972's Avatar
Default Re: Windsheild wiper issue 1992 S Model (IMPORTMyth01)
I do not know what the CMS is, but there is a relay under the resistor box. That is most likely the problem. My wipers do the same thing.
Old Feb 8, 2008 | 02:42 PM
Clutch master cylinder, I thought that box only controlled the intermediate wipers though?
Old Feb 8, 2008 | 03:41 PM
2ndlife's Avatar
Default Re: Windsheild wiper issue 1992 S Model (Apex1972)
Check the relay, probably the culprit/.
Old Feb 8, 2008 | 08:16 PM
will do...ill keep informed
savemyjazz
Honda Fit
Jul 23, 2018 06:52 PM
GQ Cowboy
Dec 11, 2003 08:40 AM
Phaze1_Ls
10
Oct 2, 2003 03:48 PM
