Mahle Gold Piston wrist pin size
Old Feb 8, 2008 | 05:42 AM
lude98SH's Avatar
Default Mahle Gold Piston wrist pin size
I have a set of Eagle rods for type s rods which use .864 wrist pin. And the standard rods use a .866 piston pin. I believe that the mahle uses the .866, could anyone comfirm this ?
And if it does how hard would it be for a machine shop to open the rod end up .002 and install a new bushing ? Thats the only difference from what I understand between the two rods...correct ?
Old Feb 8, 2008 | 07:54 AM
vinuneuro's Avatar
Default Re: Mahle Gold Piston wrist pin size (lude98SH)
Should be really straight-forward for a machine to adapt the rods for larger pins.
Old Feb 8, 2008 | 09:54 PM
lude98SH's Avatar
Default Re: Mahle Gold Piston wrist pin size (vinuneuro)
ok good.
Does anyone know the reasoning behind honda designing a different wrist pin size for the type s rod ? Is there some engineering concept behind that or something ?
Old Feb 8, 2008 | 10:58 PM
98vtec's Avatar
moderator emeritus
floating wrist pins vs. pressed
CaliforniaDad
Jun 30, 2011 11:44 PM
itr_henrik
Sep 29, 2009 03:26 AM
turboex
Oct 16, 2002 06:42 PM
gsrvx
Dec 15, 2001 11:27 AM
dustin
Nov 8, 2001 02:53 PM
