Steering wheel is off center when driving on the straight road/street
Old Feb 8, 2008 | 04:56 AM
Powered by VTEC's Avatar
Default Steering wheel is off center when driving on the straight road/street
Steering wheel is off center when driving on the straight road/street. anyone knows how to cure this problem? thanks
Old Feb 8, 2008 | 05:09 AM
D50boy's Avatar
Default Re: Steering wheel is off center when driving on the straight road/street (Powered by VTEC)
Get an alignment.
If that doesnt fix the problem, pull the steering wheel and reinstall it straight.
Old Feb 8, 2008 | 05:14 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Steering wheel is off center when driving on the straight road/street. anyone knows how to cure this problem? thanks </TD></TR></TABLE>
chances are your alignment is off, time to go and get one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">
If that doesnt fix the problem, pull the steering wheel and reinstall it straight.</TD></TR></TABLE>
yeah, this isn't great advice. actually i wouldn't recommend this at all, so don't listen to him!
always do things right the first, half assing it will only cost more time, money, and fustration.
OP, if the alignment doesn't work then i would have some one look at your suspension. make sure there isn't any damaged parts or chassis.
this should be seen though during the alignment. make sure where ever you go, the technician has been at this for years, he will be able to point out exactly what's wrong.
Old Feb 8, 2008 | 05:43 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Steering wheel is off center when driving on the straight road/street (D50boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">If that doesnt fix the problem, pull the steering wheel and reinstall it straight.</TD></TR></TABLE>
No Fix the problem don't hide it.
Worn out LCA bushings can cause this problem as well OP.
Old Feb 9, 2008 | 10:09 PM
D50boy's Avatar
Default Re: Steering wheel is off center when driving on the straight road/street (philosofy1)
I ment after he gets the alignment guys.
It could be aligned and tracking straight on the highway but someone installed the wheel crooked. He didn't give us much background info on the car.
Old Feb 10, 2008 | 01:25 AM
yoej8's Avatar
After the alignment and it still pulls one way or the other. It might be your tires. (more wear than the other) rotate it left to right if to check. If it pulls the other way, then thats it.
Old Feb 10, 2008 | 01:37 AM
thatonekid's Avatar
a car will always pull because of the angle of the street, well maybe here in san jose lol. It could also be your tires PSI or wear
deviant1
Oct 17, 2005 10:16 PM
PleaseHelp
Sep 14, 2005 09:29 PM
socalep3
Jan 27, 2004 07:57 PM
dohc-nyne
Apr 29, 2003 01:39 PM
