FS: PARTS PARTS PARTS.... Moving Sale all must go (SoCal) Pomona, Ca
Old Feb 7, 2008 | 07:36 PM
formervendor's Avatar
Banned
Default FS: PARTS PARTS PARTS.... Moving Sale all must go (SoCal) Pomona, Ca
My last thread kept getting lost... despite the updates and new parts being added so I decided to make a new post.
Payment can be sent to duckiller01@yahoo.com
Call 562-477-9257 for questions...
36mm RSX Type S DSS Stg. 2.9 Axles $300.00 pr. (Less then 100 miles on one and the other is new)
Stock Type S Axles $80.00 pr. (Inner Joint on One needs to be rebuild)
RSX Type S ABS $25.00
RSX Type S Doors w/ Glass $90.00 ea. (Pick-up-only)
RSX Type S Fenders $60.00 ea. (Pick-up-only)
RSX Type S Hood $90.00 (Pick-up-only)
RSX Type S Trunk w/ Glass $150.00 (Pick-up-only)
RSX AC Compressor $70.00
RSX rear-view mirror $15.00 (Universal)
RSX Rear Mount $25.00
RSX Pass. Mount $35.00
RSX Drivers Mount $20.00
RSX Type S MUGEN Ft. SwayBar $125.00
RSX Type S Titanium Rear Strut Bar $110.00
RSX Type S Titanium Front Strut Bar $100.00
RSX Type S LCA & Knuckles $130.00
RSX Type S Fuse Box $30.00
Radiator $90.00
Radiator Over-flow Tank $10.00
Lenso 17" x 7" 5 x 114 +42 $250.00 or w/ 95% 205/40 Toyo T1S $450.00 or Tires Only $200.00
Sparco Seat Brackets $60.00
More parts to be added as we tare the car apart...
My Parts from previous builds...
JDM H22 Longblock $650.00 (Pictures Coming)
1999-2000 OEM Civic Fog Lights (complete and used for less then a week) $100.00
Spal 12" HO "Pusher" Fan (less then 100 hours) $95.00
Half Shaft Heat-Shield $20.00
K Series Speed Sensor's $25.00 ea.
2003 RSX Type S Tranny $700.00 Will Include 3 Qts. of OEM MTF. NOTE: Speed Sensor Not Included
DSS Stg. 2.9 H22 Axles for Hasport EKH2 Kit $300.00 (NEW)
1996-1998 Civic Front End Harness $25.00
H22 Engine Harness $70.00
Shift linkage W/ ES Busings (Came from EK4 w/ B18C5) $30.00, Dual Bend Shifter $30.00 or Both for $50.00
CTR Power Adjustable Mirrors (Not Power Folding) $180.00 **Fits 1996-2000 Civic 2dr./ 3dr.**
Porsche 996 Front Calipers (NEW) $300.00 **Includes Pads**
Ignition Coils $60.00 (Set)
K Series Adjustable Short Shifter Lever $80.00
K Series Power Steering Pump w/ AEM Pulley $45.00
K Series Belt Tensioner $15.00
K Series ACT HD Pressure Plate (1500 miles) $80.00
K Series ACT Street Disc (1500 miles) $50.00
K Series Clutch Slave $25.00
EP3-R Rear Rotors (100 miles) $40.00pr.
Starter $80.00
AEM Fuel Pressure Regulator Pt# 25-300C (NEW) $80.00
AEM Fuel Pressure Regulator Pt# 25-300R (NEW) $80.00
AEM B Series Cam Gears Pt# 23-802C (NEW) $80.00pr.
Hasport RSX Pass. Mount $35.00
Turbonetics Evolution Gate (NEW) $120.00
Turbonetics Raptor BOV (NEW) $120.00
Spearco FMIC (NEW) $250.00
VTC Solenoid $50.00
K20 Dip Stick $10.00
K20 Chain Cover $30.00
TW Sensor $10.00
Knock Sensor (Black) $25.00
RSX Head Bolts $20.00 (Per Set)
RSX Type S cams $90.00 (Two Sets Avail.)
K20A Skunk2 Stage 2 Cams $300.00 (3500 miles)
RSX Type S Intake Valve Springs $20.00 (Set of 8)
RSX Type S Exhaust Valve Springs $20.00 (Set of 8)
K Series RBC Gear $45.00
K Series Exhaust Gear $15.00
K Series valve Cover (Acura) $40.00
K24A4 Oil Pump $35.00
Engine/ Manifold Cover $15.00
Old Feb 7, 2008 | 08:08 PM
A-'s Avatar
A-
Default Re: FS: PARTS PARTS PARTS.... Moving Sale all must go (SoCal) Pomona, Ca (eK24monster)
Old Feb 7, 2008 | 10:58 PM
HiyahBeech!'s Avatar
bump! too bad u wernt around when i broke my mounts
Old Feb 7, 2008 | 11:03 PM
A.E Motoring's Avatar
Default Re: (HiyahBeech!)
Old Feb 7, 2008 | 11:13 PM
shillsdc2's Avatar
Default Re: (Dual Cam Racing)
Old Feb 8, 2008 | 12:29 AM
Phack_Dat!'s Avatar
bump
formervendor
Feb 7, 2008 08:11 PM
formervendor
Jan 28, 2008 12:50 PM
formervendor
Jan 28, 2008 12:49 PM
tucker3113
Aug 17, 2005 10:59 PM
