SQUEAKY CLUTCH CABLE TRANNY
Old Feb 7, 2008 | 06:13 PM
pinks11's Avatar
Default SQUEAKY CLUTCH, CABLE TRANNY
hey guys, my clutch pedal has been squeaking a lot when i press the clutch pedal down, and the pedal feels really stiff. I know wd40 will prolly help, but i dont know where to lube it up at, and the weird thing is that my pedal doesnt have that "loose, rebound that most cars have. Any help would be appreciated.
Old Feb 7, 2008 | 06:16 PM
DIYMIKE's Avatar
Default Re: SQUEAKY CLUTCH, CABLE TRANNY (pinks11)
mine squeaked for awhile....then it broke off.....and i had to get it welded
be prepared.
Old Feb 7, 2008 | 10:23 PM
rd91sib18c5r's Avatar
Just follow the pedal arm up, and use something better than wd40 try tri flow.
Wd40 is a solvent not a good lube.
Old Feb 7, 2008 | 11:05 PM
x4thGenCafe's Avatar
OF THE KINGS
wow come to think of it mine just started like . . . . yesterday
Old Feb 8, 2008 | 12:29 AM
pinks11's Avatar
Default Re: SQUEAKY CLUTCH, CABLE TRANNY (DIYMIKE)
hey mike, i feel kinda the same way rite now that its gonna break off... but im not sure if its the transmission itself and if it has anything to do with the throw bearing. I am going to swap a b20 into my car with a heavy duty clutch so i wouldnt want the bracket to go out on me... But as of now it sure seems that way.
Old Feb 8, 2008 | 12:30 AM
pinks11's Avatar
Default Re: SQUEAKY CLUTCH, CABLE TRANNY (rd91sib18c5r)
are you talking about the part where the spring connects to?
Old Feb 8, 2008 | 03:59 AM
I lubed the pivot area liberaly and the spring, I also tried to spray into the cable
under the hood were it connects to the tranny. It worked for me. good luck
Old Feb 8, 2008 | 05:59 AM
Hondaisok's Avatar
My 91 Civic STD did the same thing until I sprayed the pedal area w/PB blaster. It just started squeeking again, so I must reapply it.
Old Feb 13, 2008 | 10:01 PM
pinks11's Avatar
Default Re: SQUEAKY CLUTCH, CABLE TRANNY (Hondaisok)
yeah i might get the spray for it. I will be doing a motor swap this weekend and i will be using a stage 2 6-puck clutch. So Im not sure if my pedal is going to feel the same, if even more f'ed up. Does anyone know if the pedal stiffness comes from the throwout bearing, or even the clutch cable (oem one snapped, currently running one from autozone). Ive driven a few other hondas in a couple of days and their clutch pedal feels nothing like mines even with a stage 3 clutch...
89civicsiowner
May 24, 2009 05:29 PM
andrey320
Feb 25, 2008 04:21 PM
jwbnavy
12
Dec 2, 2007 06:36 PM
kc90hb
14
Dec 28, 2004 10:21 PM
Khmi
10
Mar 15, 2004 12:26 AM
