will any d15-d16 5spd fit in the crx?
Old Feb 7, 2008 | 04:09 PM
HondaHeddie's Avatar
Default will any d15-d16 5spd fit in the crx?
I only want to know if the housing will work.
I plan on stripping it and filling it with gears I choose
or do I need a crx housing
Old Feb 7, 2008 | 04:12 PM
mullet eater's Avatar
Default Re: will any d15-d16 5spd fit in the crx? (HondaHeddie)
Im pretty shure that all D cases are the same but not positive!
Old Feb 7, 2008 | 04:26 PM
iNDiO's Avatar
im sure it will. if its a D then it will most likeliy work.
Old Feb 7, 2008 | 04:56 PM
so the mounts will line up from a car other than a crx?
Old Feb 7, 2008 | 05:03 PM
typer1997's Avatar
all d series are the same .just watch out because a zc tranny uses teg axles
Old Feb 7, 2008 | 05:06 PM
Default Re: (typer1997)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer1997 &raquo;</TD></TR><TR><TD CLASS="quote">all d series are the same .just watch out because a zc tranny uses teg axles</TD></TR></TABLE>
If I am pulling all the guts out and redoing it that wont apply here right?.
I am replacing, everything inside.
I only plan to use the housing
Old Feb 7, 2008 | 06:29 PM
Default Re: (HondaHeddie)
Yes you should be fine.
Old Feb 7, 2008 | 06:32 PM
whiteknightef's Avatar
The housings will all fit. If you change to newer year trannies, Good luck with the mounts unless you get hasport's d-series mount conversion kit.
Old Feb 8, 2008 | 11:29 AM
typer1997's Avatar
you should be fine with any tranny.its wierd u no how to switch out the gears but you dont know anything about the trannys.
Old Feb 8, 2008 | 11:42 AM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer1997 &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine with any tranny.its wierd u no how to switch out the gears but you dont know anything about the trannys.</TD></TR></TABLE>
Old Feb 8, 2008 | 11:46 AM
wiZCo's Avatar
Stouts 'n' Scotch
Any L3 case will work. Just make sure you shim the diff out properly unless you use the one that came with the case you're using.
Old Feb 8, 2008 | 12:21 PM
jlicrx's Avatar
there are two different cases for the 88-91 L3 transmission - one with the larger bearings and one with the smaller bearings - you need to have the right case to match the bearings
Old Feb 8, 2008 | 12:55 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: will any d15-d16 5spd fit in the crx? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">there are two different cases for the 88-91 L3 transmission - one with the larger bearings and one with the smaller bearings - you need to have the right case to match the bearings</TD></TR></TABLE>
I always forget about that. That actually screwed me up last summer when rebuilding a trans, go figure.
Can't you tell which is which by the casting #? I think I saw a thread on that in the FAQ.
Old Feb 14, 2008 | 04:27 PM
I dont mean to say I know how to swap gears.
I have not built a tranny, but I need to rebuild mine, and rather than take my car off the road for the time it will take to rebuild, I plan on building another and simply swapping it out. This way I will have my car to get things and running into surprises as I learn will not be as big a deal as it could be.
Since I am going to be stripping the tranny I figure I may as well put the best gears in while I am replacing things.
As far as the bearing size issue. What does the difference affect?
G-Auto*Hero
Aug 4, 2011 03:15 PM
88crxhfb16
Aug 10, 2006 01:31 PM
Mavrick
Sep 17, 2005 05:45 AM
dragEF8
11
Aug 20, 2004 06:19 PM
It's*BOLO!!
May 10, 2003 02:23 PM
