Car cuts off after i shift it into Reverse
Old Feb 7, 2008 | 04:08 PM
xxpnoyballa543's Avatar
Default Car cuts off after i shift it into Reverse
I had one of my hoses bust over the weekend and i found out it was the one for my transmission fluid. I put more fluid in and the car idles higher than it used to and it cuts off a couple seconds after i shift it into reverse. idk if the cutoff is caused by too much or too little ATF. and idk why the idle would have changed because of that. a little help?
Old Feb 7, 2008 | 06:52 PM
hondadude's Avatar
Default Re: Car cuts off after i shift it into Reverse (xxpnoyballa543)
hmmmm Well all hondas have a DIPSTICK so you can check the trans fluid level with the engine off.
But I just can't remember where the trans fluid line is on that 79 Accord with the Hondamatic 3 speed
bassamillion
Apr 15, 2025 08:43 PM
SpazMan
Oct 21, 2014 03:22 PM
PA07
Transmission & Drivetrain
Oct 11, 2014 06:37 AM
fallbacdun
Oct 13, 2009 07:53 PM
meangreenEG
32
Jun 28, 2007 11:09 PM
