HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING?
Old Feb 7, 2008 | 02:14 PM
supermario680's Avatar
Default HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING?
if anyone has replace their cv joints/front axles did you ever have a problem with the damper fork through bolt just Spinning?
more
https://honda-tech.com/zeropost?cmd=fshow&id=1
Old Feb 7, 2008 | 04:48 PM
Mikey3000's Avatar
Default Re: HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING? (supermario680)
you mean when you try to take it off the nut doesn't come off?
Old Feb 7, 2008 | 05:03 PM
97grnrs's Avatar
Default Re: HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING? (Mikey3000)
its either stripped or stuck in the bushing depending which bolt u mean... the 14mm one has threads and comes out about half way till u gotta knock it out.. the 17mm on the bott has a 17mm nut on the other side and can get stuck in the bushing.. just knock them out hard.. maybe use a torch if needed
Old Feb 8, 2008 | 03:26 PM
Default Re: HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING? (97grnrs)
yeah its the bottom 17mil got the nut off but the bolt will not come out, we tried with a hammer, air hammer, and mini sledge, but still nothing, I think ill try the torch idea, as it is 2 degrees here.
Old Feb 8, 2008 | 06:48 PM
beanbag's Avatar
If it spins, that just means that you need to use a thinner rod and push it out thru the other side
Rand The Man
Jul 6, 2010 09:54 AM
supermario680
Suspension & Brakes
Feb 9, 2008 10:07 AM
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
libby12060
Jun 19, 2004 03:31 PM
SC0TT
Jul 23, 2003 05:21 PM
