My first gen B16 wont pass smog.
Old Feb 7, 2008 | 02:13 PM
killrB's Avatar
Default My first gen B16 wont pass smog.
I have a 91 acura integra and a 1st gen B16 swap in it. I took it to the ref and failed with gross polluter status. Since then Ive replaced both O2 sensors and the cat with new. Ive traced the wiring to the O2 sensors and they seem to be wired right . Still my hydro carbons are too high on test even after the new parts. So whats the problem is it because I'm using the j spec ecu? Any help with this would be great.
Old Feb 8, 2008 | 02:07 AM
ghostskinner's Avatar
Default Re: My first gen B16 wont pass smog. (killrB)
try a usdm ecu and see what happens
Old Feb 8, 2008 | 07:25 AM
killrB's Avatar
Default Re: My first gen B16 wont pass smog. (ghostskinner)
what ecu would i be looking for?
Old Feb 8, 2008 | 02:55 PM
DAneronimo's Avatar
you'll have to use an obd1 ecu and get a conversion harness, since there are no usdm obd0 b-vtec ecu's
Old Feb 8, 2008 | 06:24 PM
tnez's Avatar
Default Re: (DAneronimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAneronimo &raquo;</TD></TR><TR><TD CLASS="quote">you'll have to use an obd1 ecu and get a conversion harness, since there are no usdm obd0 b-vtec ecu's</TD></TR></TABLE>
x2... get the del sol vtec emissions components and ECU, or you can look for the EM1 99 civic SI stuff but it might cost more.
Old Feb 8, 2008 | 06:52 PM
killrB's Avatar
Default Re: (tnez)
If I'm gonna step up to obd1 then I'll need an obd1 distributer aswell right?
Old Feb 11, 2008 | 11:37 AM
tnez's Avatar
Default Re: (killrB)
yup... distributor, harness, ECU, o2 sensors.
Old Feb 11, 2008 | 03:45 PM
killrB's Avatar
Default Re: (tnez)
when you say harness you mean obdo to obd1 conversion harness from boomslang or company like that right? Also can I just use one of my o2 sensors that I'm running right now as they are both new?
tjlewis10
Oct 8, 2018 06:53 AM
killrB
Apr 4, 2012 10:55 PM
nikitad
Northern California (Sales)
Sep 29, 2008 07:31 PM
ZCHF
12
Nov 17, 2005 03:03 PM
ohn0itsnate
Aug 12, 2004 04:34 PM
