Which ecu for h22 swap in accord
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmk21 »</TD></TR><TR><TD CLASS="quote">Which ecu should i use for my h22 swap into my 95 accord ex ? Should i use my stock accord ex ecu or is there one better?</TD></TR></TABLE>
chipped P28. either crome tuned or Hondata, etc... but forget the prelude brain, or the accord, or the Gsr brain.. just run the P28. i've had lots of H22 swaps and they all ran the best on a chipped p28. even a good basemap on a p28 will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr »</TD></TR><TR><TD CLASS="quote">
chipped P28. either crome tuned or Hondata, etc... but forget the prelude brain, or the accord, or the Gsr brain.. just run the P28. i've had lots of H22 swaps and they all ran the best on a chipped p28. even a good basemap on a p28 will work. </TD></TR></TABLE>
Well he could run any chipped P06/P08/P13/PR4/PR3/P71/P72/P28/P30/P61...they all use the same board, just some need extra stuffs for b-tak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">
Well he could run any chipped P06/P08/P13/PR4/PR3/P71/P72/P28/P30/P61...they all use the same board, just some need extra stuffs for b-tak.</TD></TR></TABLE>
he could run any brain..... but its a case of do you want to? who cares about the knock sensor. or the butterflies or the other various garbage that the other ecu's will throw a code for. why wire up all this unnecessary stuff. P28 uses the minimum sensors and still works great.
he could run any brain..... but its a case of do you want to? who cares about the knock sensor. or the butterflies or the other various garbage that the other ecu's will throw a code for. why wire up all this unnecessary stuff. P28 uses the minimum sensors and still works great. </TD></TR></TABLE>
I have a P61 and I am throwing no code for EGR or IAB's and neither are wired up. Plus, it's usually cheaper to find the PR4's and P06's
I have use a P28 in my 95 and have no problems no IAB's wired and just took the knock sensor out... and if your planning on using hondata i would use a P28, 72, 30 so you can use it. Hondata isn't compatible with the P13 i believe.
C_Rock77
Mar 24, 2008 07:20 PM
