B18C1 with B16 head in civic sedan
Old Feb 7, 2008 | 12:46 PM
GSX 4G63T's Avatar
Default B18C1 with B16 head in civic sedan
My buddy recently bought a usdm block with gsr piston and rods. The question he is asking me and that I am unsure of is that will he need a different ecu than PR3 for vtec. The crank is gsr and micropolished and balanced. it is also sleeved. He wants to go all motor in a sleeper sedan. he also asking me which I am unsure if he will need the 94-01 axles and shaft. He asked me if stock rods are best with the pr3 pistons for 11.7:1 compression ratio. Should he run eagle rods. The pistons are also pressed on. Does anyone have a write up? If not him and me will do a write up for you guys? I checked a shop $120 for all four.
Old Feb 7, 2008 | 01:05 PM
SIred91's Avatar
Rainman
Default Re: B18C1 with B16 head in civic sedan (4163175587)
So mister know it all cant answer a simple thing like that?
Go to your know it all website you are so fond of and get the info.
If you cant do that, then go check the FAQ.
By the way, match the ECU to the head you use. Even you should know that.
Old Feb 7, 2008 | 01:10 PM
akandok's Avatar
Default Re: B18C1 with B16 head in civic sedan (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">So mister know it all cant answer a simple thing like that?
By the way, match the ECU to the head you use. Even you should know that.</TD></TR></TABLE>
Hey, be nice. He's an 07 with a sleeper
Plus I am confused.. $120 for all 4.. What the (insert profane word here) are you talking about?
I think what you have there is a poor mans type-r. Use the Search function again
Old Feb 7, 2008 | 01:17 PM
GSX 4G63T's Avatar
The GSR wrist pin are pressed on the P72 Pistons. We told the shop how much it would cost to remove old P72 pistons and press the Pr3 pistons on for higher compression. He told us $120 for all four and should be done tomorrow afternoon. The question is that the rods are 98378 miles. Should he go with some eagle rods?
Old Feb 7, 2008 | 01:22 PM
SIred91's Avatar
Rainman
Default Re: (4163175587)
If you are going to boost it then yes, If not, its a waste of money.
You come off on other people like you already know all this ****.
Why are you now asking these rudimentary questions?
Old Feb 7, 2008 | 01:24 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (SIred91)
LOL@poor mans R.
******* head on a good block = hella fast?
This isn't even a real questions.
god phone # you let me down normally I can laugh at you.
Old Feb 7, 2008 | 01:25 PM
GSX 4G63T's Avatar
The block is sleeved from AP and the seller told my buddy that its for All motor application. My buddy then told me that lets go turbo. I said why since the block is expensive to replace. If you blow it up then time to ask your girl for some more money. I am not mr know it all. I been a lurker for 17 years.
Old Feb 7, 2008 | 01:26 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">The block is sleeved from AP and the seller told my buddy that its for All motor application. My buddy then told me that lets go turbo. I said why since the block is expensive to replace. If you blow it up then time to ask your girl for some more money. I am not mr know it all. I been a lurker for 17 years.</TD></TR></TABLE> bewst + old rods and nearly 12 comp ?
What the hell are you babbling about.
Old Feb 7, 2008 | 01:27 PM
GSX 4G63T's Avatar
Eagle Rods then?
SIred91's Avatar
Rainman
Bullshit. You wouldnt have to ask these questions if that were true.
What you mean is you are only 17.
Old Feb 7, 2008 | 01:28 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">Eagle Rods then?</TD></TR></TABLE> why not.
This isn't real and you won't listen anyway.
GSX 4G63T's Avatar
Wiseco Pistons? ARP bolts? 1 layer gasket?
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">Wiseco Pistons? ARP bolts? 1 layer gasket? </TD></TR></TABLE> t-66 with a motec exhaust
2 bottles, the big ones... by tonight.
Old Feb 7, 2008 | 01:29 PM
GSX 4G63T's Avatar
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> why not.
This isn't real and you won't listen anyway.</TD></TR></TABLE>
how many shots do you want. This is real? He got the whole stuff laid out?
Old Feb 7, 2008 | 01:30 PM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> t-66 with a motec exhaust
2 bottles, the big ones... by tonight.</TD></TR></TABLE>
Turbo? He wants to be a winner not a cheater and does not want boost?
Old Feb 7, 2008 | 01:32 PM
akandok's Avatar
Rods don't deteriorate. So 90k miles is nothing. bolts and bearings is what I would be concerned about.
Old Feb 7, 2008 | 01:33 PM
Ass$nyper's Avatar
Turbo? He wants to be a winner not a cheater and does not want boost? </TD></TR></TABLE> Sweet god, if I had the power to turn off your moms aol.....
Old Feb 7, 2008 | 01:35 PM
GSX 4G63T's Avatar
You mean my buddy's girl aol
Old Feb 7, 2008 | 01:36 PM
GSX 4G63T's Avatar
Default Re: (akandok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok &raquo;</TD></TR><TR><TD CLASS="quote">Rods don't deteriorate. So 90k miles is nothing. bolts and bearings is what I would be concerned about.</TD></TR></TABLE>
Stock rods vs eagle with $1000 budget my buddy girl has for tax return
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">You mean my buddy's girl aol </TD></TR></TABLE> Can't get a girl yourself have to share one?
Or maybe you think you are such a good friend you take his whale g/f to red lobster and get to play make out party with her.
either way kid, listen you A lie non stop B don't know anything C copy paste everything D have no real exp.
You arn't useful liked or wanted here, so umm.. yea log off .
Old Feb 7, 2008 | 01:37 PM
Ass$nyper's Avatar
Stock rods vs eagle with $1000 budget my buddy girl has for tax return</TD></TR></TABLE> you get tax returns on welfare?
sweet
Old Feb 7, 2008 | 01:40 PM
GSX 4G63T's Avatar
Have you read my avatar? yeah, you better read that again. Don't make me tase you bro.
Old Feb 7, 2008 | 01:41 PM
Ass$nyper's Avatar
Quoted for threat.
I'm only doing this because that's ban worthy.
I'd love to see you try anything.
Old Feb 7, 2008 | 01:44 PM
GSX 4G63T's Avatar
Oh a threat. CRX Toad has been notified.
Old Feb 7, 2008 | 01:48 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">Oh a threat. CRX Toad has been notified.</TD></TR></TABLE> Call it a bitch move, but anything to get rid of your troll self.
