ECU Problem! Help Me! Help Me!
Old Feb 7, 2008 | 09:37 AM
allenclan1's Avatar
Default ECU Problem! Help Me! Help Me!
Guys I'm a little over my head with an ECU issue. First a little background. 92 Integra GS. No issues, at all. Then, Tuesday I ran into a store for a drink and she would not start when I came out. Towed her home and started diagnosing. I found my check engine light stays on after placing the key in the on position. Fuel pump never starts. Bench tested main relay and it worked fine. I found the problem to be I am not getting a ground from the ECU to activate the second relay (which turns on the fuel pump). All the voltages on the relay are as they should be. I jumpered the main relay plug and the fuel pump worked fine. Now, I'm trying to figure out what would prevent the ECU from grounding the relay coil. I opened up the ECU and everything apprears normal. Could it be a bad ECU or am I missing something really obvious. My ECU is a PR4-A11. Any ideas would be very appreciated. Thanks guys!
DeLorean00
Sep 7, 2019 09:54 AM
averyvm
Engine Management and Tuning
17
Aug 2, 2013 05:40 AM
DDTECH
May 11, 2012 08:42 PM
krysted9354
20
Apr 8, 2009 03:32 PM
Keri's_baby
Jan 6, 2006 07:25 PM
