Suspension & Brakes Theory, alignment, spring rates....
4x114.3 conversion on my DC [QUESTION]
Old Feb 7, 2008 | 07:39 AM
Soichiro-son's Avatar
Default 4x114.3 conversion on my DC [QUESTION]
A guy is selling me a 4x114.3 96 J Spec Integra conversion. My question is what parts can use from my original 4x100 lug pattern suspension.
He says that the front hubs need to be pressed on to another set of spindles. I believe they need wheel bearings can I use 94-00 Integra GSR wheel bearings?
This is what he will be giving me:
Front Hubs
Front Calipers
Front Rotors
Rear Hubs
Rear Calipers
Rear Rotors
Is this all I need to complete the conversion???
Thanks!
Old Feb 7, 2008 | 03:06 PM
Targa250R's Avatar
be professional
Default Re: 4x114.3 conversion on my DC [QUESTION] (Soichiro-son)
It would probably help if you mentioned what car you're intending to do this conversion with . . .
Old Feb 7, 2008 | 07:45 PM
BlueIntegraBoy's Avatar
Default Re: 4x114.3 conversion on my DC [QUESTION] (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">It would probably help if you mentioned what car you're intending to do this conversion with . . .</TD></TR></TABLE>
Title says DC, so 94-01 Integra 3dr.
Anyways, the 4x114.3 is waste of money. The brakes are the same size as the stock Integra. Plus, finding rims will be a little more difficult as well as trying to buy replacement rotors.
To OP: You can use stock 94-01 Integra wheel bearings.
Old Feb 7, 2008 | 08:08 PM
highroller54's Avatar
Default Re: 4x114.3 conversion on my DC [QUESTION] (BlueIntegraBoy)
the rear hubs will not work on stock dc rear spindles. The bearing in the hub is wider like a 5 lug type-r. I have a full 4x114 setup that I have modded in every way possible from stock to spoon to mugen ect. pm me if you have any questions.
CoryDHorne
May 23, 2014 09:16 PM
Soichiro-son
Feb 7, 2008 08:23 AM
Soichiro-son
Suspension & Brakes
Jan 30, 2008 10:44 AM
superman67
Dec 25, 2002 08:49 AM
