fan not coming on...
i got a 95 ls, wit JDM B16.. my fans r not coming on.. replace fan switch located at thrmo housing, and nothing. when i turn on my a/c, both fans turn on.. i replaced both fans. and the headers i got, 2 and 3 has smaal cracks in them where welded area is.. and leaks a little water.. is this normal???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceyazzie »</TD></TR><TR><TD CLASS="quote"> i replaced both fans. and the headers i got, 2 and 3 has smaal cracks in them where welded area is.. and leaks a little water.. is this normal???</TD></TR></TABLE>
1. why would you replace the fans if they worked w/ the a/c?
2. what does a cracked header have anything to do with your fans?
are you sure you replaced the temp switch and not the temp sensor?
try hot wiring the fan to your battey, or another power supply. Then you can run a switch so you can turn it on/off w.e you want (ghetto) but its a way to see if its the fan motor that is bad or something else
hotcivicsi
19
May 15, 2009 01:54 PM
tianporn
Jul 29, 2005 11:44 PM
