Broken ball joint
Old Feb 7, 2008 | 05:14 AM
bow tie's Avatar
Default Broken ball joint
this is for the outer tie rod, the one that connects to the back of the knuckle. instead of a ball joint popper i just tapped it a few times with the hammer. when i reassembled every thing i noticed i must have hit it wrong because the threads on the tie rod/balljoint bolt kinda closed in. thus, i couldnt get the nut back in. is there a re-threaad tool i can go buy or use?
edit: found my solution, thanks!
Modified by bow tie at 9:08 AM 2/7/2008
Old Feb 7, 2008 | 05:41 AM
PrinceAli132's Avatar
Default Re: Broken ball joint (bow tie)
Not sure if its fixable or not.
But for next time, I've seen people put the castle nut back on at the tip and then use the hammer to hit the balljoint as to not mushroom the bolt.
Ali
Old Feb 7, 2008 | 05:46 AM
jhammond_82's Avatar
Reject Papi
Default Re: Broken ball joint (PrinceAli132)
you could probably get a die to fit that. although, i've bought some die's in the past and they are not cheap, for a good one at least.
Old Feb 7, 2008 | 05:53 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Broken ball joint (jhammond_82)
just get a new BJ....
Old Feb 7, 2008 | 07:14 AM
siksdb8's Avatar
Default Re: Broken ball joint (GRAF-FITI)
yeah a new ball joint is probably the quickest and least expensive option. its not that difficult to remove and replace that ball joint either. I've done both my lower ball joints within the last few months.
Just disconnect the knuckle and have a go at it!
Old Feb 7, 2008 | 07:27 AM
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">just get a new BJ....</TD></TR></TABLE>
Old Feb 7, 2008 | 07:32 AM
bow tie's Avatar
Default Re: Broken ball joint (siksdb8)
the ball joint boot is still fine, but like i stated, the bolt is mushroomed. are all the ball joints the same and can i get them from places like autozone?
Old Feb 7, 2008 | 07:34 AM
GRAF-FITI's Avatar
* B A N N E D *
yes autozone has lifetime warranty too
Old Feb 7, 2008 | 07:48 AM
siksdb8's Avatar
ok you just confused me.
are you talking about the big ball joint that goes through the knuckle and into the lower conrol arm?
or are you talking about the outer tie rod?
Old Feb 7, 2008 | 07:49 AM
bow tie's Avatar
my bad man, i meant tie rod.
Old Feb 7, 2008 | 08:07 AM
bow tie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siksdb8 &raquo;</TD></TR><TR><TD CLASS="quote"> or are you talking about the outer tie rod?</TD></TR></TABLE>
yeah looks like its prolly cheaper to just replace the whole tie rod. i'll do that today if oreiilys has any of that moog brand. thanks for the help guys.
Old Feb 7, 2008 | 08:26 AM
siksdb8's Avatar
good luck!
btw with the outer tie rod you can tap the tie rod it self with a hammer instead of the thread
BCGARAGE_ED7
13
Feb 11, 2013 01:47 AM
OblivionLord
Jan 14, 2010 07:21 AM
msinsky14
Apr 16, 2007 11:03 AM
LX4CYL
16
Feb 13, 2005 03:12 PM
97hb
Mar 9, 2002 11:31 PM
