help help hep!!! b16a siR EF9 engine!!!!!!!!
Old Feb 7, 2008 | 12:24 AM
swiftjdmzc's Avatar
Default help help hep!!! b16a siR EF9 engine!!!!!!!!
i have a b16a and i wanted to know is it safe to install CTR pistons that are .5 over bore or should i get ctr pistons that are stock size!!! well can somone tell me what i need to do to have these pistons in that engine and if it would run good and wont break down!! what do i need to do!!!
Old Feb 7, 2008 | 12:55 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: help help hep!!! b16a siR EF9 engine!!!!!!!! (swiftjdmzc)
You cannot install oversized pistons on a stock bore. If you go oversize, then the cylinder bores need to match the size of the new piston plus the piston to wall clearance. That is something a machine shop will help you with. Measuring inside bores accurately takes a lot of practice and good tools.
Old Feb 7, 2008 | 01:33 AM
swiftjdmzc's Avatar
Default Re: help help hep!!! b16a siR EF9 engine!!!!!!!! (Maxbore.com)
thanks!! yea i know that i have to bore the block!! but i wanna know if its ok to install pct(CTR) PISTON IN A B16A!!
Old Feb 7, 2008 | 01:55 AM
swiftjdmzc's Avatar
bump me! somone tell me!!
Old Feb 7, 2008 | 06:27 AM
stockbee's Avatar
from your punctuation, I wonder if you talk like a giddy school girl...... I just had to say it.
.periods work.
Yes it's perfectly fine to install CTR pistons in a B16A. It bumps the compression up nicely and allows you to make more power. It's a good supporting mod for cams in the future as well, because you'll actually be able to take advantage of the extra compression you're running.
91teg
64
Aug 22, 2011 03:34 PM
EK4 hatchback
Aug 11, 2010 08:29 PM
rallytyper
Feb 13, 2006 01:13 PM
asiansgoweeee
10
Jun 9, 2004 10:13 AM
