code 10, 14
Old Feb 6, 2008 | 07:00 PM
IHEARTMYHONDA91's Avatar
Default code 10, 14
ive got a '89 crx dx throwing a code 10, and 14. ive replaced the iac valve, checked all the sensors, tried resetting the ecu and still cannot figure out what is wrong with the car. its ideling rough after it warms up. it idles between 900 and 1300... i dont know some one help.
by the way it is the stock motor and stock ecu.
Old Feb 6, 2008 | 07:41 PM
hondacrashdummy's Avatar
Default Re: code 10, 14 (IHEARTMYHONDA91)
did you try changing intake air temp (code 10 IAT).
Old Feb 6, 2008 | 07:46 PM
check resistance on th IAT, should be between 1k-4k
as it warm up, resistance should go down
Old Feb 7, 2008 | 03:42 PM
is that a sensor onthe intake mani somewhere?
Old Feb 7, 2008 | 04:08 PM
mullet eater's Avatar
Default Re: (IHEARTMYHONDA91)
Number 10 is the intake air temp sensor. Take it out and clean it off with brake parts cleaner if it has any cracks or bumps or any thing not normal replace it its like ten bucks at any parts house.
Nuber 14 is the idle air control valve its on the back side of your intake manifold you can try to take it off and clean it but it probobly just needs to be replaced you can prob get one at any junk yard cheep make sure you clean it befor you put it on!
Good luck!
Old Feb 7, 2008 | 09:38 PM
thanks!
Old Feb 7, 2008 | 09:53 PM
whiteknightef's Avatar
noobs helping noobs hahaha great!
Old Feb 7, 2008 | 10:58 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Re: (whiteknightef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteknightef &raquo;</TD></TR><TR><TD CLASS="quote">noobs helping noobs hahaha great! </TD></TR></TABLE>
LoLzzZzZzzz
Im prettty sure I myself am a n00b kind SiR
Old Feb 8, 2008 | 07:24 AM
jlicrx's Avatar
sounds to me like you have the connectors for the two sensors switched - the EACV connector is green and has blue/yellow and black/yellow wires - the IAT connector is white and has red/yellow and green/white wires - switch the connectors around and reset ECU and codes should be gone
Old Feb 9, 2008 | 03:20 PM
problem solved! thanks
Old Feb 11, 2008 | 03:46 PM
sashaval22's Avatar
whats was the problem
Old Feb 14, 2008 | 03:44 PM
ok... so its been a couple days. the car is still throwing a code 10 until it warms up. then i can shut the car off and the check engine light turns off. its still surging while its idling. is there anymore suggestions? im about to loose it on this car. ive had it for almost 2 weeks and have done nothing but try to make the damn thing run decent. please help!
Old Feb 20, 2008 | 01:53 PM
Bump...
anyone have any suggestions?
Old Feb 20, 2008 | 09:20 PM
bump...
come on guys this is honda-tech you guys are supposed to be fast with some answers...
eric1180
Aug 20, 2010 04:44 PM
slacks
Sep 20, 2007 07:24 PM
Intellect
Feb 3, 2006 12:10 PM
beedoublejay
Aug 21, 2005 03:28 PM
delsol2005
Aug 4, 2005 07:20 PM
