HELP!!! car has issues and the Acura dealership gave up!!!!
Old Feb 6, 2008 | 06:40 PM
jdmmachine's Avatar
Default HELP!!! car has issues and the Acura dealership gave up!!!!
i have a 2000 ls with Idle issues similar to what has been posted. Between 14 and -31F degrees my cars idle wanders and eventually goes into a weird wander that reminds me of a rev limiter at 1500 rpm and the choke kicking of on a carberated car. Then it throws a PENDING code for IACV malfunction!!! So far i have replaced the IACV, bench tested the new IACV, checked TPS, checked IAT, replaced coolant temp sensor, replaced MAP, and checked all voltages from ecu. After all this i gave up, brought it to the only local acura dealership who spent two days and eventually gave up on it and suggested i try somwhere else, so i took it to Honda and they couldn't figure it out either after bringing my car there 2 times!!! If anybody has any suggestions it'd be great!!
Old Feb 6, 2008 | 06:51 PM
jdmmachine's Avatar
Default Re: HELP!!! car has issues and the Acura dealership gave up!!!! (jdmmachine)
bump
Old Feb 6, 2008 | 08:22 PM
jdmmachine's Avatar
any ideas???
Old Feb 6, 2008 | 08:41 PM
jhammond_82's Avatar
Reject Papi
when the car is warmed up do the rpm's go back down? does it run normal after this?
Old Feb 6, 2008 | 09:04 PM
ls19integra95's Avatar
Default Re: HELP!!! car has issues and the Acura dealership gave up!!!! (jhammond_82)
mine did a very similiar thing and what was wrong with mine was i actually had the ground wire to the top of my thermostat housing lose... have you checked all your grounds?
Old Feb 7, 2008 | 05:37 AM
jomama's Avatar
on a side note, did acura and honda charge you to look at your car?
Old Feb 7, 2008 | 08:05 AM
jdmmachine's Avatar
Default Re: (jomama)
i havent look at the grounds but i know the ones ive seen could use replacing and no acura and honda did not charge me, they just were as frustrated as me that they couldn't figure it out
Hondaguy83
Dec 3, 2012 10:02 PM
hondastrtracr
Apr 20, 2006 11:19 AM
92TypeR
Sep 26, 2002 12:17 AM
