turn signal CAI duct
Old Feb 6, 2008 | 02:40 PM
23series's Avatar
Default turn signal CAI duct
Yes I know this is a "B.A." 4gen and I give them mad props, but does anyone know where that little duce/vent in the place of the turn signal can be found?
Old Feb 6, 2008 | 02:43 PM
95greenlude's Avatar
Default Re: turn signal CAI duct (23series)
thats aries car, and your not going to "find" that piece, make one yourself
Old Feb 6, 2008 | 09:19 PM
Hawkze_2.3's Avatar
Default Re: turn signal CAI duct (95greenlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">thats aries car, and your not going to "find" that piece, make one yourself </TD></TR></TABLE>
Yep, you won't find one anywhere.
Old Feb 6, 2008 | 10:47 PM
23series's Avatar
ya I know its aries car, well now that I have no chance of finding them , do you have any ideas on how to make one?
Old Feb 6, 2008 | 11:04 PM
PinoyShadow's Avatar
You need a dremel and some cojones, that is just about it.
Old Feb 6, 2008 | 11:15 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 23series &raquo;</TD></TR><TR><TD CLASS="quote">
ya I know its aries car, well now that I have no chance of finding them , do you have any ideas on how to make one?</TD></TR></TABLE>
If you look at it, it would appear to be a stock signal with a hole cut in it. So, get a turn signal (stock or not) and cut a hole in it. Might also be good to make sure your air filter is behind it and you might make some ducting to get the air to the right spot.
Old Feb 7, 2008 | 03:40 AM
94vtirozguy's Avatar
i took a dremel to the reflector next to the indicator.
then got some sikiflex and some mesh to allow more air into that area where the CAI filter sits
Old Feb 7, 2008 | 07:14 AM
mgags7's Avatar
Or, you could make better use of your time, and wash/wax your car.
Old Feb 7, 2008 | 07:50 AM
MLBZ521's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Or, you could make better use of your time, and wash/wax your car.</TD></TR></TABLE>
lol, I love Matt.
He makes me all happy inside when I'm disappointed from the things I read.
Old Feb 7, 2008 | 08:24 AM
mgags7's Avatar
Default Re: (MLBZ521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">
lol, I love Matt.
lol. I was on an ******* spree this morning. Its over now though, I just finished test 2 of 2 today. 1 more tomm morning and then I'm off to the mountains to snowboard for the weekend w000000t. btw, too
OP, if you really need to do this, you should look into dryer exhaust tubing, it is very bendable and quite inexpensive.
Old Feb 7, 2008 | 03:25 PM
23series's Avatar
Default Re: (94vtirozguy)
thanks for all your ideas but is there any other pics of the finished product on 4th gens other then aries lude
Old Feb 7, 2008 | 04:01 PM
mattsnooz's Avatar
Your serious about flexable exhaust tubing/ducting? I'm not disagreeing at all because I've used it myself playing with different intake methods in the fourth gen body.
Ie. remove resonator, and run filter where resonator would be, than creating a mesh inlet from tire spin, (ofcourse an air bypass is smart to prevent hydrolock and ofcourse the filter gets dirty fast, but its easy to remove and clean).
I just want to know for sure its safe. I know it wouldn't be wise to use outside engine compartment though unless sealed somehow, so probably straight aluminum would be safest inbehind bumper under the splash shield.
(on another note on intake, as far as FI is concerned how does the inlet pipe diameter into the throtle body affect airflow, and pressure? what is more efficient to produce power? Or is that all based on the Turbo itself so would be hard to linearize?) I know I could search but I'm sure I'd get the best answer right from the horses' mouth!
HiyahBeech!
Jul 2, 2008 03:31 PM
ek hatchhh
Jan 20, 2007 12:15 AM
99CivicCoupe
Honda S2000
Dec 18, 2006 06:15 PM
vietnogi
Jun 25, 2005 03:47 PM
importdude2000
May 27, 2005 04:33 PM
