FS: H22 engines , CP pistons , SA00 helmet , 350lb 7" springs
Old Feb 6, 2008 | 01:55 PM
TeamNextGenChris's Avatar
Default FS: H22 engines , CP pistons , SA00 helmet , 350lb 7" springs
this is all from an uncompleted racecar project i bought.
----H22 head parts from the below engine.head casting is junk,most other stuff is good.cams,etc. are good.
cam caps,valves cover,VTEC solenoid sold...tell me what you need.$$
<U>SOLD!!!!</U>-----G-Force open face helmet.SA2000 rated.Large size...great condition,has four track days on it.$75<U>SOLD!!!!</U>
----7" long,2.5" diameter,350lb springs.$20+shipping.
<U>SOLD!!!!</U> ----CP pistons for H22.stock bore.looks like 9:1 compression.some wear on skirts.there's a nick on the edge of one piston,should be easily massaged out.$60<U>SOLD!!!!</U>
<U>SOLD!!!!</U>----H22A4 short block.stock internals....dropped a valve.head is basically useless.short block has a busted up piston.may be able to overbore the stock sleeves,or may need to be sleeved.perfect for somebody wanting a short block to build up.lower timing belt gear and water pump are gone.
$100 for the short block.PICK-UP ONLY!<U>SOLD!!!!</U>
<U>SOLD!!!!</U>-------H22 JDM short block.stock internals.i do have the windage tray and oil pickup to be included.missing water pipe on back of block.$125ICK-UP ONLY!<U>SOLD!!!!</U>
<U>Check out my other FS post:</U>Integra swaybars,LCAs,engine mount inserts,auto to manual conversion parts,H/F clutch and flywheel
https://honda-tech.com/zerothread?id=2197897
All prices do not include shipping.
located in Roanoke,VA.Paypal add 3%.
many vouches if needed.
THANKS
Chris
Modified by TeamNextGenChris at 10:10 PM 2/10/2008
Modified by TeamNextGenChris at 9:20 PM 2/20/2008
Modified by TeamNextGenChris at 5:43 PM 2/23/2008
Modified by TeamNextGenChris at 7:56 PM 2/29/2008
Modified by TeamNextGenChris at 7:20 PM 3/8/2008
Modified by TeamNextGenChris at 7:21 PM 3/8/2008
Modified by TeamNextGenChris at 6:30 PM 3/9/2008
Modified by TeamNextGenChris at 11:06 PM 3/15/2008
Modified by TeamNextGenChris at 9:44 PM 3/25/2008
Old Feb 8, 2008 | 03:12 AM
Default Re: FS: H22 engines , CP pistons , SA00 helmet , 350lb 7" springs (TeamNextGenChris)
still FS!
Old Feb 8, 2008 | 04:36 AM
accordfan's Avatar
on the h22 why are the holes for the front motor mount filled????
Old Feb 8, 2008 | 04:41 PM
Default Re: FS: H22 engines , CP pistons , SA00 helmet , 350lb 7" springs (accordfan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfan &raquo;</TD></TR><TR><TD CLASS="quote">on the h22 why are the holes for the front motor mount filled????</TD></TR></TABLE>
they're not.it's from dirt dobbers.
Chris
Old Feb 9, 2008 | 06:35 PM
up
Old Feb 14, 2008 | 11:04 AM
up
Old Feb 17, 2008 | 04:56 PM
still for sale.
Chris
Old Feb 20, 2008 | 05:21 PM
still for salez.
Old Feb 22, 2008 | 11:41 AM
low prices!
Old Feb 23, 2008 | 01:44 PM
H22s and pistons sold!!!
Old Feb 25, 2008 | 03:52 PM
good stuff!
Old Feb 26, 2008 | 03:08 PM
up!
Old Feb 29, 2008 | 03:56 PM
cam caps sold!
Old Mar 2, 2008 | 07:29 AM
up!!
Old Mar 5, 2008 | 02:45 PM
up!
Old Mar 8, 2008 | 03:20 PM
up
Old Mar 9, 2008 | 02:31 PM
helmet price lowered.
Old Mar 15, 2008 | 07:07 PM
valve cover,VTEC slenoid sold!
Old Mar 18, 2008 | 03:28 PM
up
Old Mar 23, 2008 | 12:49 PM
up
Old Mar 25, 2008 | 05:44 PM
helmet sold!
Old Mar 30, 2008 | 02:49 PM
up
Old Apr 6, 2008 | 03:35 PM
up
Old Apr 18, 2008 | 05:22 PM
up!
Old Apr 22, 2008 | 07:42 AM
up
SIXTY
Feb 28, 2009 08:06 AM
TeamNextGenChris
Apr 22, 2008 07:42 AM
TeamNextGenChris
Mar 24, 2008 01:38 PM
budget
Jul 31, 2005 12:37 PM
