ok final thing left, wiring the fogs
i did all wiring by my self, this is the switch i pulled of a dash, and i dont know what the wires are?!
yellow, red/black, black, white/red
plz tell me which goes where
white - is for the fogs
black - is for ground
red - is for power
yellow - i believe is for switch power
i have an ej2 which is different than yours, so im not sure if wiring is same or not, but should be good enough to help u out..
red - is for power
u can call any of the places that sell them an just tell'm u bought a set of fogs an didnt get any wiring information, an within seconds over the phone a tech will give it to you.. thats how my homeboy found out his ****..
ok well maybe u didn't understand what I was saying...
if ur lookin for a wire diagram but can't find one, call the place that sells the fogs, wether it be OEM honda fogs you'd call Honda, if its Depot you call depot... I gaurentee none of them are gonna make you prove you bought the lights from them, when your just asking what wires go to what...
so just because u dont live in usa doesnt mean anything... dial 1(xxx)xxx-xxxx and ur good.. i called usa numbers when i was in italy, so im sure u can too.. GL tho...
+1 Absolutely use a relay unless you want to replace the switch in a day. Remember, the wire that goes from the passenger compartment to the engine compartment is already there from the factory. It's a single wire and it's tied behind the fuse box with a piece of blue tape. Under the hood, you'll find the same piece of blue tape on the same color wire.
It's the wire that hooks to your fogs. It plugs into the relay harness and supplies the 12 volts to the fogs. You then just hook your ground up on the radiator support.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 »</TD></TR><TR><TD CLASS="quote">dude u r loaded looool, if u cant help me plz keep ur comments to ur self (no offence)</TD></TR></TABLE>
i hope ur not referring to me..?? all i did was post helpful information that anyone could have found out in 2 seconds on google lol...
Spaceballsthelunchbox
Welding / Fabrication
Jun 21, 2005 06:04 AM
