hondata s100 red light
Old Feb 6, 2008 | 09:09 AM
skUnK2jdm's Avatar
Default hondata s100 red light
my car wont rev pass 3200 rpm! and i opened up the ecu and the s100 is flashing red. its in a p72 what does this mean?
Old Feb 6, 2008 | 09:19 AM
skUnK2jdm's Avatar
Default Re: hondata s100 red light (skUnK2jdm)
any1?
Old Feb 6, 2008 | 01:04 PM
skUnK2jdm's Avatar
Old Feb 6, 2008 | 06:33 PM
skUnK2jdm's Avatar
ttt
Old Feb 6, 2008 | 09:10 PM
mtber's Avatar
Did you change anything or did this randomly start happening ?
If you can't figure it out, take the ecu & car to a local hondata tuner.
Old Feb 7, 2008 | 06:11 AM
skUnK2jdm's Avatar
Default Re: hondata s100 red light (mtber)
i bought the car with the motor and ecu! and it was doing it when i got it! i tried checking the cels but its solid not spitting out codes!
Old Feb 7, 2008 | 08:54 AM
Spunkster's Avatar
Take it to a Hondata dealer that can help you diagnose the problem.
Old Feb 7, 2008 | 09:27 AM
skUnK2jdm's Avatar
Default Re: hondata s100 red light (Spunkster)
Well I look in the ecu today and I noticed the chip had a couple legs missing and a couple that were bent.! Could this be the reason my car is in limp mode?
Old Feb 7, 2008 | 09:43 AM
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">Well I look in the ecu today and I noticed the chip had a couple legs missing and a couple that were bent.! Could this be the reason my car is in limp mode?</TD></TR></TABLE>Yes sir.
Old Feb 7, 2008 | 10:04 AM
skUnK2jdm's Avatar
Default Re: hondata s100 red light (V-SPEC 1)
Can I take the chip and the s100 out? Will it run if I do that?
Old Feb 7, 2008 | 09:44 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">Can I take the chip and the s100 out? Will it run if I do that?</TD></TR></TABLE>
Not unless you cut j1 & hope th ecu was not an eprom chip based ecu to begin with.
Do your self a favor & take the car to a hondata tuner.
attack666
Engine Management and Tuning
Jan 23, 2013 09:31 AM
brandonEM1
May 9, 2012 07:06 PM
94GSRMR
Sep 29, 2010 12:06 PM
b20izzle
Dec 7, 2004 08:42 AM
b20izzle
Dec 6, 2004 09:22 AM
