VSS Interchangable?
Old Feb 6, 2008 | 02:23 AM
redrocket_ej1's Avatar
Default VSS Interchangable?
To start off i have a 95 ex coupe 5 speed with the factory d16z6. My question is can I use a VSS from an automatic? Also could I use one from a different d series transmission or even a b series? My speedo isnt working and I want to get this fixed ASAP. Any info is appreciated.
EDIT: So i searched and found that all electronic d and b series vss' are interchangable... Now all i need to know is if automatic vss are interchangable with the manual vss.. Thanks in advance.
Modified by redrocket_ej1 at 3:33 AM 2/6/2008
Old Feb 6, 2008 | 03:13 AM
lv6l's Avatar
All D series transmission's VSS will work with each other. I have tried to confirm this. I am pretty sure an automatic VSS will with on a manual and vise versa. B series VSS is where I am unsure. My guess is maybe, maybe not. Thats the best I can go with that part.
EDIT* okay i did not read your entire post; i just finish reading your "edit" section and you gave the same answer as me. haha. forget what i just post.
97dssi
Apr 17, 2011 10:31 AM
turbociv910
Jan 26, 2009 09:17 PM
v8destroyer
Dec 21, 2007 07:13 AM
Heylookits shawn
May 21, 2007 09:36 PM
demitrix
Feb 23, 2006 09:10 AM
