VFR---------->
Old Jul 3, 2002 | 06:59 AM
Blatant's Avatar
Default VFR---------->
Question for all you people out there...
Thanks for bearin' with me everyone else! Anyone can chime in, but given the nature of the VFR's Signature Rear-end, Swing arm bit, I figured VFR owners may have some first hand experience with the following.
I believe it's time to replace the chain and both sprockets. My question(s) are as follows: VFR 1990
1. I don't have alot of $ so I was thinking of doing this myself. Has anyone ever done it and how tough was it? Do you recommend doing it yourself?
2. How much should I expect to spend? I don't need the super-duty, top of the line, best sprocket and chain out there. I don't do a ton of riding.
3. If i end up going to a shop, How much should I expect to spend at the shop..or how long should it take?
4. Where should I buy these items from. Is there a solid place on the web? Should I presumably bend over and see the dealer or is there a dicent catalog I can use?
Please, by all means read and respond...your opinions, knowledge and experience are weighted heavily as I like to research all options and make the best possible decision I can.
Thanks in advance for your time with this.
Old Jul 5, 2002 | 02:52 PM
Luke's Avatar
Default Re: VFR----------> (Blatant)
Hello,
1. Best thing to do if you have any confusion is to get hold of an owners manual. Either buy one or perhaps blag one from a database.
2. Cheap chains = false economy. Sounds like i am stating the obvious but its cheaper than replacing a casing. The VFR murders chains.
3. I woud think about 2hrs max
4. Dealers sell them, try searching on aftermarket parts?
Hope that helps, rule #1 its not difficult its just you havent done it before
Old Jul 5, 2002 | 03:55 PM
Hawkrider's Avatar
It isn't difficult at all - I have Pro Arms on my Hawks . The only thing thats even *somewhat* tricky is making sure that the bolts holding the rear sprocket are done carefully as to not cause problematic runout - similar to torquing lug nuts on a car . Its always best to replace chain a sprockets together - I buy lots of stuff from http://www.azmotorsports.com - I'm pretty sure they have a special VFR section ( look under parts , then look at the menu down at the bottom in smaller text ) If you don't have a service manual - there is prolly one online at some VFR site - then you can look @ the parts diagrams @ http://www.bikebandit.com .
Old Jul 6, 2002 | 04:15 PM
meept's Avatar
Got a VFR, changed chains...it's easy. To answer your questions:
1. Do it yourself. It is not difficult, and should take an hour if you go slow or keep getting interrupted. You will want to find something to cut the old chain off...a die grinder w/ cutoff wheel works very nicely. If your new chain has a rivet master link (as opposed to a clip master link) you will want a chain tool (avail. from AZ motorsports, or borrow one from someone).
2. For an idea of price, you're talking about $90 for a chain (DID 530V O-ring, 112 links), $32 for the OEM Honda front sprocket, and $70 for the OEM Honda rear sprocket. This is based on looking around online... partsfish.com for the sprockets, and motorcycle-superstore.com for the chain.
3. They'll charge you for at least an hour's labor, plus the parts.
4. Search the internet... I have personally had good results from Motorcycle Superstore, Kneedraggers, EMA USA, AZ Motorsports, and Sprocket Specialists (links below).
Links:
Motorcycle Superstore - http://www.motorcycle-superstore.com/
Kneedraggers - http://www.kneedraggers.com/
EMA USA - http://www.ema-usa.com/
AZ Motorsports - http://shop.store.yahoo.com/azmotorsports/index.html
Sprocket Specialists - http://www.sprocketspecialists.com/
Old Jul 16, 2002 | 01:45 PM
Blatant's Avatar
Thanks much guys, I appreciate your time and response!
Hardt
Welding / Fabrication
Jan 17, 2007 05:57 PM
dornon13
Dec 21, 2006 08:08 AM
Steve91
Dec 17, 2004 05:47 PM
