Cut Harness need Oxygen sensor pin out pleez help
Old Feb 5, 2008 | 04:07 PM
sporty240's Avatar
Default Cut Harness need Oxygen sensor pin out pleez help
So i got this del sol that has plugs on the harness cut off so there is no O2 plug on it and I cant seem to find where the plug was. yes I have searched alot cant seem to find any good info though. So i need the find where to run the pins/wires on the O2 to the ECU.
Do 2 of the wires go to ground?
Old Feb 5, 2008 | 04:10 PM
97Ej6mike's Avatar
http://technet.ff-squad.com/wiring.obd2a.htm
http://spoonhonda.com/downloads.htm
Old Feb 5, 2008 | 09:01 PM
sporty240's Avatar
Default Re: (97Ej6mike)
thanks for the links, but i need the same kind of diagram for obd1, and I need a pinout for the sensor itself
thanks
Old Feb 6, 2008 | 06:01 AM
97Ej6mike's Avatar
The sensor should be 2 blacks, a white and a blue (or white and a green, depending on company). The two blacks are the heater positive and heater ground wires, the white is the power source and the blue (or green) is the signal wire.
killafred187
Dec 17, 2009 02:07 PM
hbhonda
Oct 20, 2006 06:33 PM
I Gotta Question
Jan 17, 2006 06:34 AM
PAsol_er
Apr 3, 2005 06:42 PM
Mentat Ghola
Apr 11, 2004 10:58 AM
