rear tie bar
When i was installing my beaks lower tie bar, i ran into a problem. The welded nut on the other side is stripped and now the bolt if stripped too. Does anyone know the measurement of the nut so i can re-thread it or should i just try and get the nut off and put my own on?
Also, when the beaks bar is on, the bolt is barely long enough to thread through the welded nut on the other side.. is this safe or did you guys get longer bolts?
wlee112
Jul 12, 2007 08:13 AM
SD_EM1
Jun 10, 2004 11:28 PM
