mpfi swap quick question
ive got most of the peices for my mpfi swap. the thing im having trouble finding is what is the best, and easiest intake manifold to use on my dpfi honda crx.
for the mpfi swap, i think you can use the intake manifolds off the y8,z6&a6. the sensors are all the same but the FPR and stuff might be different cus i may be wrong but the FPR's from a vtec engine feeds more fuel. i think. but yeah, i'm using a z6 manifold. good luck man! you'll wet your pants when you'll hear how much of a difference in sound after the mpfi swap is done
. goodluck!
. goodluck!
your running this on the 1.5 block right?? so it still runs alright, jus for the little extra kick you need the ex fpr?? also all the sensors and hoses hooked up the same??
nope i did a full z6 swap, block head, intake manifold blah blah minus the dizzy and ecu. i think my car would run more better using the ex fpr.. and for the connections, you gotta extended the eacv ( green ) and the tps ( dookie white ). for the tps, you gotta switch the outter wires around. Green/Yellow. then you wire up your injectors and crank sensor
Hyunbs
Jul 1, 2013 08:12 AM
Noobster425
Apr 13, 2010 06:33 PM
vtecsk8r
May 31, 2004 11:45 AM
sloweredcivic
Sep 27, 2003 11:36 AM
