JDM Wiring Question
Old Feb 5, 2008 | 01:41 PM
DC2FRMDABAY's Avatar
* B A N N E D *
Default JDM Wiring Question
Im trying to install my JDM front end headlight:
This white plug goes to the low beam socket
I already hooked up the white plug low beam socket to the HEADLIGHT as u can see..
Now, i dont know what to do with blue plug that came off from high beam from the original headlight..
PLS HELP
Old Feb 5, 2008 | 01:44 PM
imsickofrice's Avatar
that blue plug came off your USDM high beams. USDM high beams and LOW beams used two different plugs.
Do you see that plug looking thing, under your low beam headlight? youre supposed to have connectors right there. thats where you access the high beam.. fog light.. city light.. etc. pm me if you have any more questions
Old Feb 5, 2008 | 02:01 PM
* B A N N E D *
Default Re: JDM Wiring Question (DC2FRMDABAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imsickofrice &raquo;</TD></TR><TR><TD CLASS="quote">that blue plug came off your USDM high beams. USDM high beams and LOW beams used two different plugs.
Do you see that plug looking thing, under your low beam headlight? youre supposed to have connectors right there. thats where you access the high beam.. fog light.. city light.. etc. pm me if you have any more questions</TD></TR></TABLE>
HEY GUYS i need more INFO!
Old Feb 5, 2008 | 05:51 PM
superchi's Avatar
What more information do you need? The blue plug is for your high beam, use it to power and ground your high beam light so that they work. It's just a plug.
Old Feb 5, 2008 | 10:18 PM
* B A N N E D *
Default Re: (superchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superchi &raquo;</TD></TR><TR><TD CLASS="quote">What more information do you need? The blue plug is for your high beam, use it to power and ground your high beam light so that they work. It's just a plug.</TD></TR></TABLE>
Do u kknow wher i can get the plug?
Old Feb 5, 2008 | 11:27 PM
superchi's Avatar
Default Re: (DC2FRMDABAY)
The wiring I circled is the wiring harness that should contain the wires for the fog light and the high beam that lead into the plug at the end. Just open the high beam cap and figure out which wires go where, splice the blue plug off the high beam wiring and put a female spade connector on the end and plug it into that plug to get power to it.
Old Feb 6, 2008 | 09:41 PM
michael_c's Avatar
passwordjdm sells the male portion of the plug you've still got to splice the plugs into the wiring in you engine bay. here's the link if you wanna buy them: http://passwordjdm.com/Passwor....aspx
i just used some female terminals and it worked fine tho no need for me to drop 35$ on a 2$ harness
Old Feb 7, 2008 | 11:01 PM
B18 Piston's Avatar
also use this
Old Feb 14, 2008 | 12:07 AM
LaCuRa's Avatar
nice diagram, good lookin on that
Old Feb 18, 2008 | 09:52 PM
JDMDC2BOY12's Avatar
nice
Old Mar 3, 2008 | 09:14 AM
Milan0Gsr's Avatar
Default Re: (michael_c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michael_c &raquo;</TD></TR><TR><TD CLASS="quote">passwordjdm sells the male portion of the plug you've still got to splice the plugs into the wiring in you engine bay. here's the link if you wanna buy them: http://passwordjdm.com/Passwor....aspx
i just used some female terminals and it worked fine tho no need for me to drop 35$ on a 2$ harness </TD></TR></TABLE>
We understand that, but what do you splice? i think thats what his asking, and **** I need to know also, can someone show us exactly what to do?
dwils
20
Jul 8, 2012 09:52 AM
jdmturboitr
May 14, 2012 10:22 PM
KB91Hatch
12
Sep 2, 2008 01:06 AM
ITR.#1446
Aug 27, 2008 10:03 PM
98ITR#0020
Jun 22, 2002 09:09 AM
