Lighting HID/Xenon kits, Retrofits and Associated Topics
EM2 Coupe Vs Sedan OEM Headlights
Old Feb 5, 2008 | 12:39 PM
fongyz22's Avatar
Default EM2 Coupe Vs Sedan OEM Headlights
Okay, so is the cutoff the same or different on these suckers??
I know the sedan has two adjusting ***** and the coupe has one for height only and not horizontal. I currently have one DEPO-made sedan headlight it appears and the cut off is horrible; it's straight and slanted down a bit. (it's the driver's side headlight) The passenger is a regular OEM Coupe headlight and the cutoff seems to be perfect. so now I get hotspots and I can't adjust them properly...any experience?? (Also, the parking light is diffused brighter via DEPO one, the OEM is dimmer) Same with OEM sedan?
Old Feb 6, 2008 | 07:13 AM
devani's Avatar
Default Re: EM2 Coupe Vs Sedan OEM Headlights (fongyz22)
OEM sedan and coupe should be same(not noticable difference)...however you have DEPO and that could be the problem....
Old Feb 6, 2008 | 02:59 PM
fongyz22's Avatar
Default Re: EM2 Coupe Vs Sedan OEM Headlights (devani)
well i'll find some chick on campus here who drives a sedan 01-03 and compare lol.
fongyz22
Honda Civic (2001 - 2005)
Feb 6, 2008 08:24 AM
