turn signal not working but the hazard is working just fine need help plz !!!
Old Feb 5, 2008 | 11:57 AM
zc89hatch's Avatar
Default turn signal not working but the hazard is working just fine need help plz !!!
NEED HELP!!! asap 91 integra 4dr
i have search but no solution
Old Feb 5, 2008 | 12:02 PM
all-mtr-teg's Avatar
Default Re: turn signal not working but the hazard is working just fine need help plz !!! (zc89hatch)
Check your flasher or turn signal switch
Old Feb 5, 2008 | 12:07 PM
zc89hatch's Avatar
Default Re: turn signal not working but the hazard is working just fine need help plz !!! (all-mtr-teg)
how would i check the flasher and turn signal switch
Old Feb 5, 2008 | 12:56 PM
Flashers are cheap, so just buy one and replace it, if that doesn't fix it look into getting a manual to see how to diagnose and replace a faulty turn signal switch. Are all your turn signals not working or just one?
Old Feb 5, 2008 | 07:15 PM
zc89hatch's Avatar
ok heres the deal all of the signal doesnt work but the the parking light works fine, the hazard works good just the turn signal i have a plug with 3 wire coming from i believe the back of the ignition dont know where it plugs to sorry no pics
Old Feb 5, 2008 | 07:20 PM
ls19integra95's Avatar
pull the cover off your steering column, make sure everythings clipped into your turn signal switch and if so then try replacing that switch...
Old Feb 5, 2008 | 08:20 PM
Steven.'s Avatar
Default Re: turn signal not working but the hazard is working just fine need help plz !!! (ls19integra95)
could it be a bad fuse or blown bulb their is more then 1 bulb in ur turning light their is 2, when 1 is blown it blinks fast and with the hazards it may only use one of them
Old Feb 5, 2008 | 08:29 PM
r3v da t3g's Avatar
Default Re: turn signal not working but the hazard is working just fine need help plz !!! (Steven.)
hazard lights and turn signals have thier own fuse. turn signal light fuse is under the dash, hazard is in your engine compartment check easiest things first like fuse.
Old Feb 6, 2008 | 12:55 AM
TurbdEG6's Avatar
Default Re: turn signal not working but the hazard is working just fine need help plz !!! (r3v da t3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">hazard lights and turn signals have thier own fuse. turn signal light fuse is under the dash, hazard is in your engine compartment check easiest things first like fuse.</TD></TR></TABLE>
This is exactly the process to use. Check easiest components first. If no check ups/tests give you your answer, start replacing parts in order of cheapest to most expensive.
Old Feb 6, 2008 | 12:50 PM
zc89hatch's Avatar
Default Re: turn signal not working but the hazard is working just fine need help plz !!! (TurbdEG6)
check all fuses imma get a new switch and see if it works thanks
92eg_b16
Oct 19, 2008 12:52 AM
lopezchris21
Oct 16, 2008 11:03 AM
amit_b82
10
Mar 2, 2008 08:39 PM
EKhatch84
Aug 21, 2006 10:29 AM
moleodonuts
Sep 13, 2005 02:00 PM
