93 accord sunroof problems!
Old Feb 5, 2008 | 10:52 AM
pushintealhondas's Avatar
Default 93 accord sunroof problems!
yo dudes. my sunroof always used to work, and one day it stopped. Whenever i pressed one of the sunroof buttons, nothing would happen. No sound or anything. I checked the fuses and checked out the motor. I know the fuses arent blown, but im not sure if something is wrong with the motor. After like 2 weeks, the sunroof started to work again. and then after a little while it stopped working hahaha. it hasnt worked for maybe 6 months. its not completely open but it is open a little on one side allowing a lot of cool air to get in. does anyone know the problem? or does anyone know where i can get a sunroof tool to manually do it. because i dont have one. thanks a lot !!!!!!!!!!
Old Feb 5, 2008 | 11:11 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: 93 accord sunroof problems! (pushintealhondas)
Check the wiring, hopefully it's just a short or grounding itself out.
Old Feb 5, 2008 | 12:04 PM
Heat's Avatar
Check your owner's manual, see if it mentions anything about a backup way to close the sunroof. Otherwise, figure out where the sunroof motor is and remove the plastic cover over it, see if there is a place to put a flathead screwdriver.
Hopefully Honda had a backup way to close the sunroof. On my now-sold '93 Volvo there was a plastic cover over the sunroof motor, you removed that and there was a place for a flathead screwdriver over the gears. Turn that, and you manually closed (or opened) the sunroof.
As far as the problem itself goes, since it completely died / came back / died, my guess would be a short somewhere.
Old Feb 5, 2008 | 01:48 PM
Default Re: 93 accord sunroof problems! (Heat)
okay thanks a lot guys! Do you think that if I took it to a honda dealership that they would be able to close it for me? because i really dont need to be worrying about this right now. its winter and i just want to be warm inside my car! hahah thanks!
Old Feb 7, 2008 | 12:51 PM
HennessyLane's Avatar
yea for 80$ it cost 80$ just to look at it
Old Feb 7, 2008 | 05:11 PM
awdgsx96's Avatar
Our cars automatically close the sunroof when you turn the ignition off, and since you said it made no sound or movement at all during certain times, I would think there is a problem in wiring somewhere as it was mentioned before.
If it were the case that you pressed the button and it made a noise, I would point to the motor as the problem then
NOFX
Nov 30, 2023 02:23 PM
Noch
Sep 14, 2016 03:18 PM
DJ Strike It Up
Jan 1, 2010 03:18 PM
pushintealhondas
Mar 22, 2008 10:38 AM
