HOW BIG IS TOO BIG????
i figured 19 was too big, but i cant find this rims like in a 17.. i was hoping to hear to from someone running 19's and hear what they had to say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93JDM_H22 »</TD></TR><TR><TD CLASS="quote">lmao... wit the help of some crafty search engines, i found my perfect 17.. thanx for ur input tho
Thank God........anything over 17's is overkill.....theres just no reason for it.
15's FTW!!!
</TD></TR></TABLE>Thank God........anything over 17's is overkill.....theres just no reason for it.
15's FTW!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">The bigger the wheel, the higher the top speed per gear.
The lighter the wheel the faster you get there</TD></TR></TABLE>
No, that depends on tire size. Generally when you get larger wheel any place will automatically install tires which make the larger wheel add up to the same diameter as the smaller wheel with the tire included. If you get some 19s and put a huge tire with the same sidewall height as the stock tires then you will have some gearing changes.
Smaller diameter makes you accelerate faster moreso than the weight of the wheels.
nitecrawler
May 6, 2005 08:23 PM
