sputtering integra need help..
Old Feb 5, 2008 | 12:31 AM
SDP190416's Avatar
Default sputtering integra need help..
set up: LSVTEC b16/b18 chippd p28. my car start up fine and runs good on idle, but when you press the gas it sputter around 2k n up ( sound like subby engines or running on 3 cylinders. Ive changed out my caps, rotor, wires, dizzy, fuel filter, spark plugs all have sparks, getting 43 psi on my fuel press. set timing plenty of times n checked with advance timing light n its on point. no cel code. checkd my injectors n all has voltages and resistant check is good. please i really need some help, thanks...
Old Feb 5, 2008 | 05:48 PM
SDP190416's Avatar
so i checked the combustion chamber and #1, 2 & 3 has black chamber and #4 was clean, like ders no mixture going on. any idea please help me out..thanks
Old Feb 5, 2008 | 08:22 PM
SDP190416's Avatar
fixed. #4 injector was clogged. sprayed it with brake cleaner and now its fixed.....
Hondaiii3
Oct 13, 2011 10:09 PM
capm.stabahoe
Dec 27, 2008 06:17 PM
gworthyunit
Nov 19, 2006 10:28 AM
gemini05
May 25, 2006 07:41 PM
thaiphob
Jan 6, 2003 05:37 AM
