Suspension & Brakes Theory, alignment, spring rates....
Camber questions...
Old Feb 4, 2008 | 08:41 PM
brianmcivics's Avatar
Default Camber questions...
I went to get an alignment today and the front was 1.9 degrees off and the rear was 2.5 degrees off. So they recommended i get a camber kit for front and rear. They should be able to adjust the toe on the front, right? and then i could get the omni power shim kit for the back. Are the bolts longer than oem with the omni shim kit? The rear shim kit(comes with 4 bolt and 12 washers) allows up to 4 degrees of rear camber adjustment, should i be fine with that? I would much rather spend $15 on a shim kit than $100+ on a rear camber kit.lol.
Old Feb 5, 2008 | 08:39 AM
EK_B's Avatar
If you have a Civic, some washers and longer bolts would help your camber. Search for washer trick.
Old Feb 5, 2008 | 12:51 PM
bmoua's Avatar
Default Re: (EK_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B &raquo;</TD></TR><TR><TD CLASS="quote">If you have a Civic, some washers and longer bolts would help your camber. Search for washer trick. </TD></TR></TABLE>
washer trick works like a charm...dont waste your money on rear camber kits
Old Feb 5, 2008 | 08:09 PM
Default Re: Camber questions... (brianmcivics)
Thanks guys, im gonna shim the back. What about the front, should i get a front camber kit or take it to another alighnment shop?
Old Feb 6, 2008 | 07:56 AM
EK_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brianmcivics &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys, im gonna shim the back. What about the front, should i get a front camber kit or take it to another alighnment shop?</TD></TR></TABLE>
Alignment for sure the toe kills your tires way more than the camber does.
pinks11
Suspension & Brakes
Dec 7, 2007 06:43 AM
stock99si
Jul 16, 2007 09:07 AM
ek9child
Sep 21, 2006 10:23 PM
jeison
Jun 9, 2006 12:16 PM
drewbie
13
Jan 6, 2005 03:13 PM
