'94 Integra LS partout WNC
Old Feb 4, 2008 | 07:54 PM
greasemonkee's Avatar
Default '94 Integra LS partout WNC
Somehow wound up with a bunch of crap for me to trip over. There's a lot buried in these pics.
Ford truck also for sale $800 4x4. has bottom end knock when oil gets hot, but can still drive
Hood - couple small dents, hardly noticeable, $40
Carpet - some stains, may clean up decent with a little work. $30 plus ship
Trunk carpet - couple stains. $5
Sunroof - $35 plus ship
Rear dash
Driver airbag
Rear wiper assembly
Right side tail light $15 plus ship
Right headlight $15 plus ship
Middle hatch light
Under dash fuse block
Ignition switch
Headlight/wiper switch assembly
Window switches
Various dash vents
Climate control
Instrument cluster
Cruise and dimmer switch
Inner door handles
Hatch struts
Power antenna
Uncut wire harness (the main line under dash with abs and under hodd fuse box attached)
Uncut dash harness
Cable reel
Radio adapter kit
Clock
Sunroof switch
Shift ****
Rear view
Brake light spoiler strip from '98 gsr
Seat belts
Blower motor assy.
Air distributor box and heater core
AC evaporator and box
Canter console
Interior panels
Pedal cluster including booster and masters
Front swaybar and brackets for front and rear
Fuel tank and pump
Front and rear suspension (minus front struts) with brake cables and ABS wires intact
Steering column
Have some civic Eg parts also including:
Suspension minus struts
D15B8
Manual shift linkage
AC compressor
Manual trans internals
Modified by greasemonkee at 5:52 AM 2/9/2008
Modified by greasemonkee at 10:42 AM 2/17/2008
Old Feb 9, 2008 | 01:53 AM
Default Re: '94 Integra LS partout WNC (greasemonkee)
details added
Old Feb 12, 2008 | 09:11 PM
Jmay258's Avatar
* B A N N E D *
how much for the front brakes shipped to 35120 ? do you have the trans
Old Feb 14, 2008 | 06:38 AM
edited
Old Feb 15, 2008 | 11:23 PM
eg6low-buck's Avatar
Rob.
11
May 18, 2016 04:27 AM
76 camaro car
Mar 30, 2014 07:55 AM
greasemonkee
Jun 11, 2009 09:07 AM
Regal
Feb 22, 2009 12:47 AM
