car chugs in low rpms, something is NOT right
Old Feb 4, 2008 | 06:16 PM
Si Arn's Avatar
Default car chugs in low rpms, something is NOT right
ok so i nearly ran out of gas on the way to gas station. before I got there car began chugging.. as if its not getting gas. So i put some fuel injector cleaner in there and after some driving and COLD weather it got better.
one misty morning the chug came back
another night it was raining out HARD and the chug came back
tonite was a misty wet nite and the chug returned.
Its usually in the lower RPM's of any gear and around 2000 seems to pop out of this funk
this chug could be called a BUCKING perhaps? like driving and tip tappin on the break every half second
Old Feb 4, 2008 | 08:24 PM
sony224422's Avatar
Default Re: car chugs in low rpms, something is NOT right (Si Arn)
start your car and mist water over your cap.. and see if it makes the car stall. if so, you probably have a cracked cap.
or, if you want, when its dark pop the hood and see if you see any blue sparks, if you do you have bad wires.
rll2
Jan 7, 2013 08:21 AM
91b18a1ls
Feb 21, 2011 02:27 PM
Flwr
Honda Civic (2006 - 2015)
21
Dec 18, 2007 03:25 PM
almostboostedgsr
Mar 26, 2007 10:57 AM
Otherguy
10
Feb 27, 2005 10:41 PM
