Honda S2000 Honda S2000
wheel bearing
Old Feb 4, 2008 | 05:16 PM
m1northreat's Avatar
Default wheel bearing
so i searched ad read about the wheel bearig issue with my 01 s2k. it started about a month ago and kinda went away and just came back with a vengance. so now i gotta replace it. is the only place to get one of these the dealership? also the topics talk about hubs needing replacement. anyone know what the cost on these parts are and how ez the replacement will be when done at home
thnx
Old Feb 4, 2008 | 05:47 PM
Rtzx9r's Avatar
GDD 1%
Default Re: wheel bearing (m1northreat)
If you do not have one, get the helms manual and buy the parts online through a honda dealer. A search will reveal over a dozen places to get the parts much cheaper than at your local stealershp.
Old Feb 6, 2008 | 06:20 PM
Y0N1P8T5R1F5A4T's Avatar
Default Re: wheel bearing (Rtzx9r)
front wheel bearing is the biggest beotch i have ever experienced when i had my '93 civic hatch..
when professionally done..they use a press..i have an idea of how that looks and works but never seen it..they use hundred/thousands of pressure to remove the bearing from the hub..
me and my dads mechanic replaced the bearings only..that i bought from the local auto parts store(central auto parts) and we took the hub out and started hammering away the old bearings..
took us about 5 hours a hub..from start to finish..but hammering the bearing away was about 3-4 hours just to get it out of the hub..
we hammered all around evenly on the hub so the wheel bearing will come out straight..
youll know what im talking about if you ever start at home..
with an S though..i would take it to a professional..dealership..or honda/acura performance specialist..either one..as long as they have a press..for more fast and much more reliable help..
i told you professionals use a press..the next day we did the other side..
but if you would to just buy a hub you can do that easy at home..with the right tools..
im sure with an S its just about the same as any other honda..to replace hub, bearings, and etc..
good luck man..
i hate small **** like that..they're pet peeves..
Old Feb 6, 2008 | 10:57 PM
sahtt's Avatar
The stealership is known to charge upwards of 250 a wheel for front bearing replacement. A shop will probably charge about 100. Try searching "s2000 wheel bearing cost" using this auto forum search engine, you'll get a large amount of information.
Old Feb 7, 2008 | 03:21 PM
sweet thnx alot guys. imma get the bearing and hub combo from hardtopguy and ill prolly just go to a shop to have the bearing placed in the hub but ill do the rest to save money. im sayin this thinking that i can remove the hub with the bearing still in it correct. then i can just take it somewhere have it removed and another placed right? even though im gettin a new hub too. which is suppose to go bad as well.thnx for the help
CX-Adam
Suspension & Brakes
May 31, 2010 03:12 PM
bsmith100
Apr 12, 2010 08:05 AM
CTR-GSR
Jun 3, 2009 10:17 PM
g-ride-si
Sep 13, 2005 08:36 AM
opeth13
Suspension & Brakes
Jul 19, 2005 09:24 PM
