Is the countershaft for B-series tranny all the same??
Hi, I have a YS1 tranny (91-93 integra cable non-vetc) in my turbo crx and blew
the countershaft. I have friend that can sell me one for cheap, but he has the
hydrolic one( I will use only the shaft, everyhting else I will swap from mine)
Will this work??
Will this work??
i think you should usually change the final drive also with the matching countershaft. the ys1 should interchange but make sure the tranny it came from had a 4.40 final drive also. if its a 4.40 also you may be able to switch it without the final drive.
what tranny did the other one come out of.
dem0nk1d
Jan 20, 2007 12:37 PM
