WTT: 98 Red (Pink) Prelude 5 Speed (Swapped) - 134k Miles
I have an S2K now, so no need for H22 gas mileage as a beater. Want something with better MPG, so I think that probably rules out Integras.
Interested in trade for something with:
-Equal/lesser mileage and 95-96+ MY (depending on mileage)
-Cruise control preferred
-Manual transmission
-30+ MPG highway
-Not interested in EG's, DA's, EK sedan, or anything else much older than '95
-Interested in EK hatch or coupe, mostly Or a Ford Focus hatch.
134xxx on clock. ST rear sway bar, Koni Yellows, Ground Controls, camber kit (front), volk replica wheels/good ES100 tires (also have type sh wheels if you would rather those)
CLEAN TITLE
49xxx - bought 1-owner car, was a lease in Nevada. I am the second owner of this car (original plate 4ZMD864, became TEHSLOW, then replaced w/current).
62xxx air filter, spark plugs
60xxx - brake fluid flush, coolant flush, fuel filter, valve adjustment
63xxx new front rotors, front pads
82xxx new alternator
83xxx 5 SPEED SWAP: new trans (17k miles), brand new clutch, brand new flywheel, brand new master cylinder, brand new slave cylinder
89xxx rear brake pads
90xxx cap, rotor, plug wires
92xxx timing belt, tensioner, camseal, waterpump
94xxx cat converter
99xxx new front axles
114xxx MTF
122xxx new air filter, spark plugs
Regular Oil Changes
My car is in excellent mechanical condition. Idles great, drives really well. I average around 27-28 MPG sometimes a little more sometimes less depending on how much I get on it (29 if grannied). This is all freeway.
The car is in excellent mechanical condition, with a few caveats. 1. The windshield wiper fluid doesn't work. 2. The cruise control does not work.
The car could use a paint job. As you can see, the hood paint is shiny, and so are some fenders, but one front fender and the rear bumper has faded letters on it from advertisements. A truck also backed into my front bumper a couple times, chipping paint. There is also some residue on the gas cover door where there was a sticker, and glue where the front lip was. Overall looks good from afar.
The ECU doesn't read right at a sm@g station. Machine won't hook up to the ECU. I will take car of this before sale but buyer will be responsible thereafter.
Modified by sandiegan at 5:31 PM 2/6/2008
-30+ MPG highway
CLEAN TITLE
94xxx cat converter
114xxx MTF
Regular Oil Changes
SDiegoo")
Mar 22, 2015 07:44 AM
561teggy
May 15, 2013 09:33 AM
