Resealing/Assembling 3-Piece Wheels?
Old Feb 4, 2008 | 07:41 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Resealing/Assembling 3-Piece Wheels?
First of all I'm a dumbass - let's get that out there up front so there's no need to point that out to me.
With that out of the way let me tell you guys my problem:
I just bought a car that had some blue spoked Black Racing wheels - Panasport/Watanbe looking wheels. I intended to repaint the spokes only in a matte black or gunmetal finish, and I realized that taping the lips with the bolts in place would be a huge PITA.
I realized the wheels are actually very nice, 3 piece wheels so I got the brilliant idea to take the bolts out, pull the outer rim off, and easily respray the spokes, then reassemble.
Little did my ignorant *** know that once you break the seal/unbolt the rim from the rest of the wheel that they'd have to be resealed to reassemble them.
My questions:
1. I only pulled one rim/lip off of one wheel, so I know this one will have to be resealed as I can see the silicon-type material that held the rim to the wheel - is this something I can do myself?
2. I only pulled the bolts from the other wheels, and did not pull the rim off or break the actual seal/gasket material - can these simply just be reassembled/bolts and nuts put back in and retorqued?
I did find a local ATL shop to do the work, but they're calling me back with a price and I fear it'll be cheaper just to buy new wheels like Rotas/Drags etc.
Thanks in advance for any possible help.
Old Feb 4, 2008 | 09:23 PM
toyomatt84's Avatar
Sanji
https://honda-tech.com/zerothread?id=2193898
Old Feb 5, 2008 | 04:50 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=2193898</TD></TR></TABLE>
Thanks.
That helps some, but where would I get the high pressure sealant, and also that link doesn't help me to know if simply removing the bolts alone requires resealing.
Old Feb 5, 2008 | 05:46 AM
r.wright's Avatar
Default Re: (B18C5-EH2)
if you just removed the bolts and not the face from the barrel then i doubt you need resealing...bit better safe then sorry..if these wheels have 2 piece barrels (sounds like they do) then i would reseal them anyway to avoid any leakage down the road ...
you can buy silicone at any hme depot, hardware or possibly pep boys..
Old Feb 6, 2008 | 10:22 AM
AZTEKEF9's Avatar
Default Re: (Opossum Jenkins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote">if you just removed the bolts and not the face from the barrel then i doubt you need resealing...bit better safe then sorry..if these wheels have 2 piece barrels (sounds like they do) then i would reseal them anyway to avoid any leakage down the road ...
you can buy silicone at any hme depot, hardware or possibly pep boys..</TD></TR></TABLE>
what would be a good brand to use? also u only use it as a calking or u also use it as a thin gasket between the back and front barrels?
B18C5-EH2
Feb 19, 2008 04:09 PM
5thgen4dr
Northwest (Sales)
Aug 21, 2006 05:39 PM
kay_animation
Feb 1, 2005 01:35 PM
