what ecu?
Old Feb 4, 2008 | 07:32 AM
jdmjunkie8's Avatar
Default what ecu?
Im lookin at a 2nd gen crx and the guy has some ecu that doesnt work on there it has a D15B sohc vtec motor in it its running but not hitting vtec the guy said he says it has a ecu that went to a ZC but that wouldnt work so what ecu will I need?
thanks
Old Feb 4, 2008 | 07:41 AM
jlicrx's Avatar
Default Re: what ecu? (jdmjunkie8)
with the OBD! SOHC VTEC engine, to get the VTEC to work correctly, you should really convert the car over to OBD1 and use the OBD1 ECU - the D15B ECU is PO8, but P28 will also work - with any SOHC OBD0 ECU, you will need to use an OBD0 distributor for the MPFI engine and then find some way to control VTEC - you could use a PR3 or PW0 ECU (both are OBD0 and VTEC) but they are for the B16A and won't work very well with the D15B
Old Feb 4, 2008 | 10:10 AM
jdmjunkie8's Avatar
Default Re: what ecu? (jlicrx)
How much do you think that would run me to get it wired up for OBD1? Or is there a write up on how to do it yourself, I couldnt find one. Any help would be great. Thanks
Old Feb 4, 2008 | 10:17 AM
dr_latino999's Avatar
Did I hear D.I.Y.?
https://honda-tech.com/zerothread?id=1319235
Old Feb 4, 2008 | 02:43 PM
jdmjunkie8's Avatar
Default Re: what ecu? (dr_latino999)
thats an amazing thread, thanks dude
DAtegLs
Dec 22, 2009 10:56 PM
xander1100
Engine Management and Tuning
Apr 26, 2009 09:29 PM
ViperRedCRX
Apr 12, 2003 07:43 PM
