OBDI B18b swap in a DA?? what all do i need for swap
Old Feb 3, 2008 | 06:56 PM
EFOwNzALL's Avatar
Default OBDI B18b swap in a DA?? what all do i need for swap
just wanting to kno everything i need, i got motor n trans, and wiring harness for conversion....thanx
Old Feb 3, 2008 | 07:00 PM
jhammond_82's Avatar
Reject Papi
Default Re: OBDI B18b swap in a DA?? what all do i need for swap (EFOwNzALL)
uumm.... just pull yours out and put the new one in.
Old Feb 3, 2008 | 07:29 PM
UmbraDc2K's Avatar
Maybe some aftermarket mounts.
Old Feb 3, 2008 | 09:59 PM
super jdm yo's Avatar
Default Re: OBDI B18b swap in a DA?? what all do i need for swap (UmbraDc2K)
well if your da is a 92+ then you're fine, because it's already a obd1. but if your car a obd0 then the easiest and cheapest route would be to swap the new manifolds with your old ones and use your old distributor and alternator. also the transmission off of those are hydro so you'll need to use your old transmission too. just use your old mounts as well.
so to make a long story short, pretty much all you'll be using is the b18b block and head with this route.
another thing, i think that theres a difference in where the thermoswitch is located on b18a and b18b. you might want to look into that if you want your radiator fan to work properly.
Old Feb 3, 2008 | 10:07 PM
northemt88's Avatar
x2
it will work like a charm, my friend has a 96 head that he is running as obd 0
Old Feb 4, 2008 | 06:10 PM
EFOwNzALL's Avatar
yea my DA is a 92, so its already OBDI? appreciate the info, i also have a cable B16 trannny, hopefully ill see a sufficient diff. in acceleration
Old Feb 4, 2008 | 06:25 PM
DA_9's Avatar
Default Re: (EFOwNzALL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFOwNzALL &raquo;</TD></TR><TR><TD CLASS="quote">yea my DA is a 92, so its already OBDI? appreciate the info, i also have a cable B16 trannny, hopefully ill see a sufficient diff. in acceleration</TD></TR></TABLE>
oh Yeah ou will def. see a difference.
Old Feb 4, 2008 | 06:29 PM
01teggy's Avatar
im pretty sure u just need mounts. possibly hasport for the smart decision.
Old Feb 4, 2008 | 06:46 PM
EFOwNzALL's Avatar
my only problem is that i rele dont want to put a hole in my pocket over gas mileage becuz of that shorter gearing, i want to keep my Ls 5th gear but i dont trust myself cracking open that tranny and what not...dont rele want to shell out a lot ov money for it either lol
Old Feb 5, 2008 | 08:50 AM
northemt88's Avatar
Default Re: (01teggy)
You can use the stock mounts and i would suggest using them unless they are completely f-ed.
IMO....Speaking from experience, Hasports are no better really unless you are making major hp.
Ebay mounts work 100% just as perfectly awesome but are 1/3 the price.
Stock mounts will ride a lot smoother then after market solid core mounts any day.
shocker85
Jan 22, 2010 01:48 AM
blue92eg6
Aug 2, 2009 02:47 PM
h22_crx
Jun 3, 2007 02:36 PM
ACrite3404
Apr 27, 2004 06:19 PM
177ik3
Aug 2, 2001 07:43 AM
