need help identifying a turbo?
Old Feb 3, 2008 | 03:56 PM
Manny86's Avatar
Default need help identifying a turbo?
the turbo is a turbonetics turbo it has a t/4 flange for the exhaust manifold the in take inlet sizxe is 4" but the fan center is 2" the outlet on the cold side say's .50 inside of it the exhaust side say's .53ar or .58ar i cant make it out but where the flange for the manifold is it says .58 inside of it and the downpipe is a round four bolt style thanks for your help.
Old Feb 3, 2008 | 04:55 PM
Manny86's Avatar
Default Re: need help identifying a turbo? (Manny86)
bump.
Old Feb 4, 2008 | 06:00 AM
TheShodan's Avatar
Moderator
Please measure Inducer/exducer of the compressor and exhaust wheels. The covers will have to be removed to measure properly. The numbers you've given are generic for A/R of the covers that you are using.
Old Feb 4, 2008 | 06:34 PM
Manny86's Avatar
Default Re: (TheShodan)
what do i use to measure them ?
Old Feb 4, 2008 | 07:49 PM
Schister66's Avatar
Man U FTW
a micrometer
Old Feb 5, 2008 | 01:13 PM
Manny86's Avatar
I measured the turbo today and i got 3.000 for the exducer and 2.230 inducer for the compressor wheel, and 2.503 exducer and 2.888 inducer for the turbine wheel.
Old Feb 5, 2008 | 01:25 PM
turbodano's Avatar
Default Re: (Manny86)
post some pics.
Old Feb 5, 2008 | 01:32 PM
Manny86's Avatar
Default Re: (turbodano)
how do i do that ?
Old Feb 5, 2008 | 02:00 PM
Schister66's Avatar
Man U FTW
http://www.photobucket.com
...here i thought it was common knowledge
Old Feb 5, 2008 | 02:10 PM
Manny86's Avatar
Default Re: (Schister66)
lol sorry one min ill hace those pics
Old Feb 5, 2008 | 02:13 PM
Manny86's Avatar
http://s270.photobucket.com/al...4.jpg
Old Feb 5, 2008 | 02:14 PM
Manny86's Avatar
http://s270.photobucket.com/al...3.jpg
Manny86's Avatar
http://s270.photobucket.com/al...2.jpg
Old Feb 5, 2008 | 05:32 PM
Manny86's Avatar
can anyony help me find out what size this turbo is i was told to post up the size for the comp and turbine but nobody responds.
Old Feb 6, 2008 | 08:26 AM
Manny86's Avatar
bump for help
Old Feb 6, 2008 | 08:49 AM
agrn93ls's Avatar
here I embeded the photo's for you
Old Feb 6, 2008 | 09:58 AM
SL0WEGG's Avatar
Default Re: (agrn93ls)
Looks like a straight T4
how big is the inlet on the compressor side? if its 3" also, from your measurements, its a t4/t04e 57 trim.
Old Feb 6, 2008 | 12:41 PM
Manny86's Avatar
Default Re: (boostedej1)
the compressor inlet is 4" but it reduces to about two 2" or so.
Old Feb 6, 2008 | 06:31 PM
TheShodan's Avatar
Moderator
that is a 54 trim 76.2mm exducer (similar to a 57 trim) T4, using a smaller stage II wheel. (based upon the information given). This COULD work, but from the T4 flange, keeping the volute higher with energy based upon your displacement may prevent it from being "enjoyable"
Old Feb 6, 2008 | 07:28 PM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">that is a 54 trim 76.2mm exducer (similar to a 57 trim) T4, using a smaller stage II wheel. (based upon the information given). This COULD work, but from the T4 flange, keeping the volute higher with energy based upon your displacement may prevent it from being "enjoyable"</TD></TR></TABLE>
I think what he is trying to say is "damn thats a big turbo and you gonna need a big motor"
Old Feb 8, 2008 | 02:50 PM
Manny86's Avatar
i have a sohc vitara build with eagle rods etc. will it work with my motor or is it to big ?
Max McNasty
Apr 28, 2011 01:22 PM
02type-sk20
Aug 4, 2010 11:08 AM
Coutts
Jul 18, 2010 06:23 PM
taggart_lumpy
Feb 16, 2007 11:13 PM
ITR981002
Nov 26, 2002 02:29 PM
