Distributor Question
Old Feb 3, 2008 | 01:11 PM
spooncivic01's Avatar
Default Distributor Question
With the distributor removed from the engine should I be able to rotate the rotor.
Old Feb 3, 2008 | 02:44 PM
Crx Jimmy's Avatar
Default Re: Distributor Question (spooncivic01)
yes , the rotor should spin very easily if the dizzy is removed. if it doesnt you need a new dizzy, the bearing is probably Fvcked
Old Feb 3, 2008 | 02:50 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Distributor Question (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">yes , the rotor should spin very easily if the dizzy is removed. if it doesnt you need a new dizzy, the bearing is probably Fvcked</TD></TR></TABLE>
i second this.. if it doesnt spin.. it may have serious problems.
Old Feb 3, 2008 | 02:58 PM
Default Re: Distributor Question (sanimalp)
thanks, how are the distributor king dizzy's. I have an obd-0 B16
Old Feb 3, 2008 | 05:30 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic01 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, how are the distributor king dizzy's. I have an obd-0 B16</TD></TR></TABLE>
They are fine, probably better than finding a 18 year old used one
EG_LS
Nov 19, 2007 03:04 PM
bigluelok
Jul 10, 2007 12:16 PM
crazykamper
May 3, 2006 03:56 PM
Magic Wheels
Nov 18, 2005 06:45 PM
moochik84
11
Jan 26, 2004 07:10 AM
